Old 09-27-2009, 08:18 AM   #1 (permalink)
Hypermiler
brucepick's Avatar
Lean Burn Civic - '97 Civic HX
90 day: 47.09 mpg (US)
Stiffener bar for soft front aero deflector
Installed aluminum stiffener bar for aero deflector that's at rear of the front bumper cover. This is the one that flops around a bit, has a formed notch for the exhaust downpipe. Attached with alum. pop rivets. Stiffener is on top side.
I used a bit of aluminum angle stock that was originally for flooring installation. Is like angle iron except the raised side of the angle is only about 3/16 inch, not equal to the width of the other 'leg' of the stock.
Watch out for bracket at lower corner of radiator, drivers side - the bar was hitting it so I added some foam pipe insulation for padding held in place with duct tape. Would have been better to grind away a bit of the new bar's material before riveting into place.
Check your tire pressure - keep it up !!
We've learned that diet has a closer relationship to cancer than we ever thought. Please see this Wikipedia article on The China Study.
Driving Lean Burn '97 Civic HX, lotsa mods by now! '89 Volvo 240 is semi-retired. I did love that car though!
I think its time to start my aero journey! pumafeet10 Aerodynamics 17 09-10-2009 02:09 AM
Civic grill block, front undertray, tire deflectors daqcivic Aerodynamics 24 05-13-2009 04:52 AM
Aero deflector Kururu Aerodynamics 7 09-28-2008 11:24 PM
Aero Front End Possibility? Coyote X Aerodynamics 12 06-07-2008 01:43 AM
