Old 04-06-2009, 02:21 PM   #11 (permalink)
B2300 - '96 B2300 SE
Big Red - '88 Concours ZG1000
90 day: 54.41 mpg (US)
Zongshen Sierra 200 - '06 Sierra 200 Supermoto
90 day: 82.11 mpg (US)
Capri Racer, Thanks for the discussion.
Out in the high desert I admit that I did see a higher than normal amount of tire separations. Especially the big rigs. That is where I really learned to avoid those especially during temperature spikes. Also saw an inordinant amount of car fires, it seems there was one fire a week on the 15 someplace! But that's another story.
One thing I look for with used tires is even tread wear. If it looks like it has been driven under-inflated it is a pass. As you know, underinflation increases heat generation very significantly.
By the way, about the study by the private investigator, how many of the 25% of unfit tires had defects that were not visible? Could you please include a link to the study? I'd like to know because there may be something I'm missing in my evaluation.
I respect your concern for the unknowns of used tires. My experience though has been good. As far as risks in life go and considering the primary failure modes of tires, the risk has boiled down to be so small that they are on the minivan that my wife carries our 6 year old and his friends around in.
Maybe tires found in Washington are less of a concern, southern states may well be a different story. I don't have enough experience with used tires there to make a call.
Old 04-07-2009, 12:53 AM   #12 (permalink)
Tire Geek
CapriRacer's Avatar
Hopefully you also know the other signs of underinflation - bead grooving and sidewall cracks.
I am not sure the study was ever published - except as part of a transcript for a lawsuit. I'll have to get back to you on that!
This is kind of what I am alluding to.
The risk may be percentage-wise small, but some of the consequences are pretty severe. It's this fact - and the fact that few people know they are experiencing a tire failure until it does - that keeps me away from used tires.
Certainly tires used in colder climates would be less prone to heat related failures - and that would apply to the population of used tires for sale in those areas. Unfortunately, loose tires can be transported quite a distance.
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 140 11-21-2011 10:13 AM
Tire Engineer here - concerned about hyperinflating tires CapriRacer Introductions 48 09-26-2009 10:25 PM
Tire pressure (of winter tires) tasdrouille General Efficiency Discussion 20 08-12-2009 02:38 AM
Hyperinflating tires CapriRacer Hypermiling / EcoDriver's Ed 218 12-11-2008 11:21 PM
Plus one tire sizing effect on mpg? 93Cobra#2771 EcoModding Central 12 10-21-2008 07:45 PM
