Did you happen to read the article comparing Ford and Chevy's newest 1-tons?
Chevy vs. Ford in Heavy-Duty Rumble in the Rockies - PickupTrucks.com News
Loaded to the max capacity, about 28,000lbs each I do believe. Drove them up Eisenhower Pass in CO, a 7% grade for 6 miles. A very good read, but somewhat excessive, as they are passing semi's that are going 15mph while going 45mph themselves. With a 1/3 the load of the semi's. Maybe I'm just crazy, but if you're pulling that much weight, GET A SEMI. Don't need a 51Ton rating? get a smaller single axle, say only 35 Tons, like the ones that run around cities instead of the OTR trucks.
Maybe it's just me, but once you exceed 20,000lbs for towing on a regular basis, it's time to uprate your towing vehicle to one that isn't testing its limits at 14 Tons.
Bah. I could rant all day, having been on both sides of the door. Once in a while, sure, the need to pull 14T is there. Deal with your slow rig, it's damned heavy! But all the time? Get a bigger truck and stop trying to pass off your daily driver as a 14 Ton towing machine.
....jack of all trades, master of none.
