Old 05-17-2016, 10:10 AM   #61 (permalink)
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
I had a 96 Suzuki Esteem sedan that got 40-42 mpg. I didn't log back then, but I calculated at every fillup. I tied a Christmas tree to the roof and drove 2 hours on the interstate, got 20 mpg for the trip.
Transmission type Efficiency
Old 05-17-2016, 10:24 AM   #62 (permalink)
Originally Posted by carolina guy View Post
Agreed...was reading just before putting the kids to sleep and haven't updated in a while. Although before one calls BS one "should" have all the information, eh? :-). Short fills are accurate to get the highway portion that I was mentioning...the city only usually yields around 15 mpg in my experience around Charlotte either light or heavy footed.
My gas log on my phone shows 17.2 mpg city / highway over the last six months / 5500 miles tracked. That includes a lot of non commute local driving and getting mulch, lumber, rock, etc while hauling the wife and 4 kids instead of just myself on the highway with cruise control.
BTW: this is without turbos...just the old Vin W 4.6 auto with 233k on the clock.
Short fills introduce large fill errors into the calcs. Unless there are enough entries to average those errors out, they are... well... prone to large error.
Even on a proper "full-fill", one tank does not a valid claim make. See: Sport Coupe.
I have all the information I need to make my call and you will not prove 21+ mpg at 75 mph. Your gas log shows a believable 17.x.
http://ecomodder.com/forum/showthrea...tml#post182705
http://ecomodder.com/forum/showthrea...g-16344-2.html
Mustang Dave (05-17-2016)
Old 05-17-2016, 11:42 AM   #63 (permalink)
90 day: 29.44 mpg (US)
I filled up my dad's F150 one time, 19 MPG at 55 MPH. That is hand-calculated. Factory gauges are often at least a couple percent high.
Old 05-17-2016, 12:03 PM   #64 (permalink)
Stormtrooper - '14 Ford F-150 XLT, 4x4, Crew Cab 5.0
Again, I will have to give your "call" a (*shrug*) as being worth what I paid for it. :-)
But FWIW here is some logging I have done with my SGII (after installing the dual efans) over the last week (cannot find the other paper I was using before the spreadsheet) so this will have to do.
This is for a 43 mile each way commute using primarily I-485, I-77 and NC Hwy 49 in the Charlotte/Cabarrus County area. The speed limit for I-485 is 70MPH and it is NOT a good idea to go so slow during rush hour! I do, however, keep it just below the Misdemeanor level of 80+MPH per NC law.
32 Miles Interstate and 10 miles state highway and about 1 mile other roads:
Date // Inbound / Outbound // SG Avg // Coolant Efan Ran // AC // Outside Temp // CC Used // CC Speed // 485 Avg HI/LO speed
5/17/2016 IN 21.4 YES NO 61 NO 0 LO
5/16/2016 OUT 21.1 YES NO 74 YES 76 HI
5/12/2016 IN 20.8 YES NO 72 YES 75 HI
5/12/2016 OUT 19.9 NO YES 87 YES 77 HI
5/11/2016 IN 21.3 YES NO 71 YES 76 HI
5/11/2016 OUT 20.1 NO YES 82 YES 78 HI
5/10/2016 IN 20.9 NO NO 68 YES 75 HI
5/10/2016 OUT 20 YES YES 83 YES 75 HI
5/9/2016 IN 21.4 NO NO 61 YES 76 HI
5/9/2016 OUT 20.8 YES NO 79 YES 76 HI
This is VERY consistent with what I have seen...and this is with a 2004 Ford F150 4.6/Auto 4x2 Supercab no bed cover with nearly wornout street radials at max sidewall PSI. The extra columns are because I have a dual e-fan setup with one fan set to start at 184F and the second at either 195F or whenever the compressor is on.
I have not done (mostly because it is a PITA) short fills, and I agree...you never know where the pump is shutting off unless you use the same pump each time, at the same angle, etc.
I will update the fuel log to show that my AVERAGE city AND highway is about 17.1 mpg based on the last 5000+ miles, but as a caveat the above is the SGII observations from the daily commutes ONLY...and that is about 80% highway from a cold start. The fuel log shows weekend driving, evening driving with the family (wife and 4 kids) hauling whatever is purchased while out and idling around town.
Old 05-17-2016, 02:40 PM   #65 (permalink)
Mazda CX-5 - '17 Mazda CX-5 Touring
90 day: 26.68 mpg (US)
Our 2006 Grand Caravan has the roof rack with removable crossbars and the only difference I ever saw w/o them was about 1mpg when running empty on my commute (27mpg vs 26mpg)
That still represents a 4% reduction in fuel economy. Not a big deal, but it all adds up.
MetroMPG (05-17-2016)
Old 05-17-2016, 03:42 PM   #66 (permalink)
Low-hanging fruit. Chop the top already.
Old 05-17-2016, 05:14 PM   #67 (permalink)
Yuppers....they stay in the garage 99% of the time.
Old 05-17-2016, 08:18 PM   #68 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
But did you have it pointy end forward (like the normies) or base end first like the template?
The Following User Says Thank You to oldtamiyaphile For This Useful Post:
MetroMPG (05-18-2016)
Old 05-17-2016, 09:21 PM   #69 (permalink)
It might have also doubled the weight of the vehicle... ;-)
Old 05-18-2016, 08:19 AM   #70 (permalink)
Rat Racer
Stump first. That may have been a decade before I'd even heard the word hypermiling, but I knew enough about aero to know that if I didn't want all the boughs pointing at the floor when we set it up, it was going stump first. And it was less than a 7' tree, so it didn't quite double the car's weight!
