Old 02-09-2018, 11:14 AM   #1 (permalink)
The Blazer - '01 Chevy Blazer LS
The Impretzel - '93 Subaru Impreza L
90 day: 32.09 mpg (US)
Subaru Impreza 6 Speed Swap
Hey guys! These forums appear to hold a huge wealth of knowledge. I have a 1993 Subaru impreza fwd with a 5 speed. I know subaru put 6 speeds in some of their more sporty go fast models. I am still researching to see if I could find a 6 speed out of one of those models that would fit in place of my 5 speed. My theory behind this would be to drop my highway cruising rpms with a 6th gear overdrive to return better highway mileage. Currently I am averaging 33mpg in mixed driving and 30 on the highway turning 3000 rpm at 65-70mph. My wheel nut has a couple screws loose so it is constantly getting tweaked for better mpgs. Any input/ knowledge would be greatly appreatiated!
Old 02-09-2018, 12:27 PM   #2 (permalink)
A madman
brucey's Avatar
Pequod - '17 Subaru Outback
90 day: 22.79 mpg (US)
Send a message via AIM to brucey
The only 6 speeds I'm aware of are AWD and geared very short.
Even if you could convert an AWD 6 speed to FWD only you would likely not see much gain because of the gearing problem.
Example:
5th in a 5 Speed Impreza is 0.780
6th in a 6 Speed STI is 0.756
A real gain of 0.024.
You might have an easier time finding a taller final drive.
Old 02-10-2018, 12:02 AM   #3 (permalink)
Stubby79's Avatar
'91 Miata - '91 Mazda Miata
90 day: 27.11 mpg (US)
'86 Fiero GT - '86 Pontiac Fiero GT
Purple Penny Pincher - '95 Pontiac Firefly Base
90 day: 43.68 mpg (US)
Jett-Black - '01 Volkswagen Jetta
90 day: 39.32 mpg (US)
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 32.24 mpg (US)
What he said. AFAIK, they went all AWD a decade or two back.
Old 02-10-2018, 11:18 AM   #4 (permalink)
Yaris verso - '02 Toyota Yaris Verso
Unto - '04 Fiat Punto
Liam nissan - '98 Nissan Almera
Maybe higher diameter wheels? Unless you drive a lot of stop&go.
Old 02-10-2018, 06:46 PM   #5 (permalink)
Usually those "sporty" 6-speeds have a narrower gear-spread, thus resorting to a shorter differential in order to provide them with some agility at the acceleration. So it wouldn't be really so useful.
Old 02-12-2018, 04:31 PM   #6 (permalink)
Good to know about the gearing. I did upgrade from 13inch wheels to 15 inch wheels with a much larger tire (they ended up weighing less than the stock 13s?) And gained almost 2 mpgs.
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
