Old 04-11-2009, 07:26 PM   #11 (permalink)
X-Frenchy: very
groar's Avatar
scenic - '01 scenic
90 day: 43.09 mpg (US)
megane - '97 megane classic
Diesel
90 day: 72.53 mpg (US)
dennisius - '06 Prius
90 day: 61.71 mpg (US)
daqcivic, I though I replied you but can't see the reply, may be I pushed on the preview button instead of the post button... Here it's.
I can't tell you about my throttle % as my cars aren't SG2 compatible. I accelerate so my butt-o-meter doesn't feel the turbo activate itself, ie I stay far from WOT (wild opened throttle).
I P&G if the coast duration is longer than the pulse duration, else I DWL (drive with load), per example when going up hills.
In city the coast duration is at least 3 times the pulse duration. It helped a lot to over inflate the tires to max sidewall. If you coast engine on, then the faster you go the more you save during the coasting phase. Also as the engine has its gph (gallon per hour) going down slowly during the first few seconds of idle, the more you glide the more you save. DWB (driving without brakes) is a good technique in city.
Denis.
Save money & CO2 at home : http://ecorenovator.org/
Created and managed by the creators of http://ecomodder.com/
Earth and health are priceless, so are kilotank and AT-PZEV
Best Mégane tank: 1268.9mi @ 77.847 MPG(US)
2008/06-2011/10 saving:
  • 5725.5 kg CO2 (5342.6+382.9)
  • Diesel / Money: 42.17% = 2446.25€ = 3357.26$
megane : thread - kill switch.
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
