Old 12-22-2014, 12:01 PM   #1 (permalink)
JDM hypeR mileR
OG VX's Avatar
The OG VX - '92 Honda Civic VX
90 day: 68.64 mpg (US)
92-95 VX: Defrost Switch Re-Purposed to become Kill Switch
Hello all, Need some help here.
I want to re-purpose a OEM rear-defrost switch to become a kill switch. Later, I will also add a second kill switch on the shift knob. I want to have BOTH options. The shift knob will have a momentary button, which I will hold down for a length of time. I would also be able to push the OEM defrost button for extended coasts/engine cut-offs.
I'll be relocating the current rear defroster and wiring to the blank spot on the LEFT side of the steering wheel. I don't won't to loose the defrost functionality. But, I want the kill switch to be on the right side, since that's a spot that's easier to get to quickly.
It should also be stated that I am using a second OEM defrost switch with a junkyard pig-tail. I want to run off the OEM wires. Any clue how I can do this? I'll try to get a wiring diagram up here, if I can find one.
I'm not going to lie, some of this is for "show" as well. I'll paint the button green and add a leaf to it. Should be a nice talking point at shows, and another element of "green" on the dash. But I do want it to be functional.
Any input appreciated, thanks!
"Yesterday as I was going in to the shop, I came upon a recently killed Armadillo in the middle of the road with one front leg sticking up. As I passed over him he "High Fived" my air dam. I thought that showed a great attitude on his part." -The Donkey CRX
Old 12-22-2014, 12:18 PM   #2 (permalink)
You'll have to wire the switches in series. The defrost switch will have to be 'on' normally so it doesn't interrupt the signal.
Old 12-22-2014, 12:56 PM   #3 (permalink)
Spaced out...
spacemanspif's Avatar
The New Focus - '07 Ford Focus ZX5
90 day: 32.44 mpg (US)
I don't understand why you need 2 switches. You say you want one for "long" shut downs but once the engine has been stopped your shut down can be as long as you want; the engine doesn't restart when you let off the momentary kill switch. It's a momentary for that reason, once your finger is off the button, the car is READY for restart whenever you are; and will do so by keying the starter or bump starting the engine.
-Mike
2007 Ford Focus ZX5 - 91k - SGII, pending upper and lower grill bocks - auto trans
1987 Monte Carlo SS - 5.3/4L80E swap - 13.67 @ 106
2007 Ford Focus Estate - 230k - 33mpg - Retired 4/2018
1995 Saturn SL2 - 256K miles - 44mpg - Retired 9/2014
Cost to Operate Spreadsheet for "The New Focus"
Old 12-22-2014, 01:05 PM   #4 (permalink)
JDM hypeR mileR
OG VX's Avatar
OK, this is concerning, as I believe the defroster switch is on a time of sorts, correct? So, that means after being "on" for a time, it will shut off and randomly cut off power to the injectors, correct? No bueno.
I see. I'm still learning on all of this. Thanks for the heads up. I guess I'll keep waiting for that new shift knob Doax is building
