Old 09-03-2008, 10:54 AM   #11 (permalink)
KickmeintheJimmy - '96 Jimmy 4 Door 4WD
Went out and finally bought a tire pressure gauge......I was running my tires (worn winters) under inflated at 30.5-31 psi vs the recommended 35 psi so I bumped them all up to 37 and then filled up. Should get a decent mpg boost from that the ride feels better too.
Old 09-03-2008, 01:15 PM   #12 (permalink)
Pencil gauge? Or dial-type gauge?
Good for your tires! Now, did you scrimp on the price...and buy a pencil style gauge? Didya know these are seldom accurate? Or, give the same no. twice in a row? The dial-type are sooo much better.
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 140 11-21-2011 09:13 AM
LRR (low rolling resistance) tires - Green Seal report & list MetroMPG EcoModding Central 38 04-13-2011 06:12 AM
Video: Can Skinnier Tires Increase Fuel Economy? Peakster EcoModding Central 62 03-12-2011 02:58 PM
[MetroMPG.com] List of reasons why your winter mileage is so bad MetroMPG General Efficiency Discussion 32 12-28-2010 10:04 AM
Crapped. 2 tires have bubbles. XyKo EcoModding Central 37 09-04-2008 04:55 PM
