Old 02-16-2008, 03:07 AM   #1 (permalink)
EcoModding Minded
Chris D.'s Avatar
Lunar Mist - '02 Tacoma SR5
90 day: 25.31 mpg (US)
Silver Streak - '08 Corolla S
90 day: 38.25 mpg (US)
Send a message via AIM to Chris D.
Super Metro (powered by CBR 600 superbike engine)
I thought some of you would get a kick out of this..
I found this when searching for Geo Metro's for sale..
enjoy..
http://losangeles.craigslist.org/lac/car/571452983.html
1993 Geo Metro 2 door hatch back.
Powered by a CBR 600 superbike engine.
Uses the bikes six speed gearbox.
Fully gutted track car with 4-point cross braced cage.
Light weight high bolstered bucket seats.
Simpson 5-point cam lock harnesses.
Painless wiring switch panel.
All lights, blinkers, horn, etc works as if the car was stock.
WILL NOT PASS SMOG. Should be used as a track car only. Thanks.
Old 02-16-2008, 12:30 PM   #2 (permalink)
EcoModding Minded
Chris D.'s Avatar
http://www.psiman.net/geo1.htm
Old 02-16-2008, 02:55 PM   #3 (permalink)
igo
igo's Avatar
Mini Box Truck - '05 Xb
90 day: 32.15 mpg (US)
It looks rust free! I wonder how fast it is and what mpg it would get.
Old 02-16-2008, 03:39 PM   #4 (permalink)
Hybrid Student Driver
RH77's Avatar
Teggy - '98 Integra LS
90 day: 33.02 mpg (US)
IMA - '010 Insight EX
90 day: 45.43 mpg (US)
Tessie - '06 TSX Base
90 day: 28.83 mpg (US)
I was thinking the same.
There's a Swift Team from Canada that participates in the Rally here in MO -- pretty quick actually.
-RH77
Supporting those devastated by the Joplin Tornado
EF5 / 22-May-2011
_
_
Old 02-17-2008, 08:53 PM   #5 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
What an awesome build!
Of course I was wondering the same thing... mpg... mpg... mpg...
Old 02-17-2008, 08:54 PM   #6 (permalink)
Oh, and since it runs through the bike's transmission... can it go backwards?
Old 02-17-2008, 10:20 PM   #7 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
Linky says no.
No mention of year of engine... since it was "cheap", it's probably not brand new... mid '90's put out about 106 hp.
What does a stripped out Metro shell with a bike drivetrain weigh- 1000 lbs?
It should go pretty good. I'd imagine they have a tough time getting enough traction at times.
I'd also imagine FE to be pretty bad, with crazy rpms at highway speeds.
Old 02-17-2008, 11:35 PM   #8 (permalink)
"Crush"
bennelson's Avatar
Electric Cycle - '81 KZ440
90 day: 334.6 mpg (US)
S10 - '95 S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Prius
90 day: 71.8 mpg (US)
Very interesting conversion.
There are some great ideas here that could be used for trike building. I like the Metros old stick rigged up for shifting the cycle engine.
This also does bring up some interesting possibilities about putting a SMALLER than stock engine in a Metro or similar.
That chain connection from the cycle tranny to the differential also looks pretty interesting and gives some ideas for different ways an electric motor could be hooked in.
The only EV Metro I ever saw had a chain going straight from the motor to the transaxel similar to this setup.
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Old 02-18-2008, 12:13 AM   #9 (permalink)
RH77's Avatar
There's a Suzuki Swift team from Québec successfully in Rally racing (from what I've seen at our competition in MO).
In our tournament, the vehicle has to be robust: "Low-Water Bridge" crossings often have at least 4-6" of water to ford at speed, and high velocities include air-time on abrupt hills. I've observed this team the last 2 years and have really been impressed with the how the vehicle holds-up. I also give the team credit for their expertise...
I wouldn't write-off the modified Suzuki-clone as a racing-machine...
RH77
EF5 / 22-May-2011
_
_
Old 02-18-2008, 01:18 AM   #10 (permalink)
Idiot Suv?? Sav?? Sev?? S
metroschultz's Avatar
SuperElasticBubblePlastic - '93 Metro plainjane
90 day: 53.91 mpg (US)
SilverHairBeauty - '01 Avalon XL
90 day: 24.06 mpg (US)
Send a message via AIM to metroschultz
Linky says no.
Thats the great thing with bike motors.
Infinite gearing possibilities.
Just change one gear @ a time and record results.
It appears to be 4:1 right now.
10 teeth on tranny 40 teeth on diff. (as best as i can count from the pics)
say you're twisting 6500rpm @ 60mph
Change tranny gear to 12 teeth and you are down to 3.33:1
now your twisting 4875rpm @ 60mph
add infinitum.
what a great way to increase engine load by reducing rpm @ speed.
if load gets too great you just change back up.
If the engine would produce enough torque you could lope down the highway @ 60mph twisting ~ 1500rpm.
That'd get you real close to 100mpg.
Just another way of looking at the equation.
Have fun.
S.
You can turn painful situations around through laughter. If you can find humor in anything - even poverty - you can survive it. Bill Cosby
Coasting experiment: engine on VS engine off on a fixed route = 12.9% gain MetroMPG Hypermiling / EcoDriver's Ed 6 02-22-2008 08:38 AM
MetroMPG.com mailbag: Metro engine won't stay warm in super cold weather MetroMPG General Efficiency Discussion 13 02-01-2008 11:28 PM
