Old 01-30-2010, 06:21 PM   #1 (permalink)
Supplier of e-car parts
I came across this when looking up e-bike parts, their bike motors are cheap and go like stink
hub motor, brushless motor, bike conversion kit, power wheelchair,electric bike,wheelchair controller,electric wheelchair, electric motorcycle,EV battery,brushless hub motor ,golf trolley,brushless joystick controller, regenerative braking controller
"High power brushless motor: 48V/72V, 3KW-20KW
Reliable high current controller: 48V/72V, 100A-300A
Integral bridge with differential gear box and brake: for all kind of car and trikes
High capacity battery packs
Other Accessories"
The Following User Says Thank You to Geebee For This Useful Post:
Christopher Jordan (01-31-2010)
Old 01-31-2010, 11:57 AM   #2 (permalink)
Ryland's Avatar
honda cb125 - '74 CB 125 S1
90 day: 79.71 mpg (US)
green wedge - '81 Commuti-Car
Blue VX - '93 Civic VX
You would get a more powerful set up with a golf car rear end if I'm not mistaken, that motor looks just slightly bigger then an Etek, and 300 amp controller is not that big for 72 volts, I would want to go with at least 600 amps as I see my 48 volt motor spike at over 600 amps to get the same power out of that 72 volt motor you would be drawing 400 amps and at times I wish that my EV had more power.
Old 01-31-2010, 01:31 PM   #3 (permalink)
Christopher Jordan's Avatar
Gopher (aka- go fer...) - '95 Aspire 2dr hatch
That might be the way to go. I just can not get any parts for the City-el. I noticed the 2009 City-el had 4 batteries on one side and the motor was on the opposite side and was moved 90 degrees from the axle. Mine is totally different. They might not have parts at the City-el factory for a centrally mounted diagonal motor surrounded by 4 batteries.
Old 02-04-2010, 09:33 AM   #4 (permalink)
Misanthropologist
captainslug's Avatar
BORK! - '89 240 DL Wagon
90 day: 21.27 mpg (US)
GoldenMotor has a fairly poor to mixed reputation for build quality and customer service. You will have better luck and better pricing if you buy used motors in the spec range you want.
The Following User Says Thank You to captainslug For This Useful Post:
Christopher Jordan (02-04-2010)
Old 10-05-2010, 03:06 AM   #5 (permalink)
clarkandrew45
Guest
Posts: n/a
Thank you for the tip captainslug. anyway, i found this site that seems to be a car Part Directory?can you help me on this? is this site is ok as a reference? Hoping to hear from you soon. Thanks.
Old 10-05-2010, 02:12 PM   #6 (permalink)
"Crush"
bennelson's Avatar
Electric Cycle - '81 KZ440
90 day: 334.6 mpg (US)
S10 - '95 S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Prius
90 day: 71.8 mpg (US)
The electric bike that I built a few years ago was using a Golden Motor wheel hub kit. It worked very well.
I simply mail-ordered it, so my only customer service experience was with their web page shopping cart. I thought the bike kit was a good item.
I do agree with Ryland that this so-called car kit looks really light-weight. It would be great for an indoor electric cart for some sort of industrial use, or maybe a fun little electric go cart - but not for what most American's think of as a "Car".
It could be used for a trike that you would have registered as an electric bike.
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Old 10-13-2010, 09:35 AM   #7 (permalink)
Ryland's Avatar
what kind of electric car parts are you looking for? there are alot of electric car parts out there, companies that make motors, controllers, adapters.
If you want something that would be comparable to the axle that was linked to then go to a golf cart shop, want it to go faster? get a larger motor for it from the same golf cart shop.
what to make a highway speed electric car? then you need to figure out what car you are basing it off of first.
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 980 04-25-2012 10:12 AM
Registering a car based reverse trike in CA Carwhisperer EcoModding Central 58 07-10-2011 07:12 AM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 54 05-08-2011 10:19 PM
Removing Parts From My Car mhmitszach Off-Topic Tech 7 06-22-2009 05:53 PM
Alt Car Expo Los Angeles 2008 cfg83 Events & Meet-ups 2 10-14-2008 06:21 PM
