Old 11-07-2009, 07:40 AM   #1 (permalink)
The Atomic Ass's Avatar
2-Wheeled Mule - '06 Burgman 400
90 day: 84.89 mpg (US)
Max - '01 S-10 LS
90 day: 24.7 mpg (US)
Twin Powa - '05 Ninja 250
90 day: 79.09 mpg (US)
Ransom - '01 Bravada
90 day: 16.39 mpg (US)
Send a message via Skype™ to The Atomic Ass
Suspension theory
I've read here that while perfectly aligned wheels front and back might be good for FE, they generally make for a squirrelly-handling car.
Am I remembering correctly, that a car will generally track straight, but will squirrel in turns, or is it that the car won't track straight with perfect alignment?
What I'm brain-storming here, is for my future not-even-on-the-drawing-board electric car, a suspension system wherein all adjustable elements, (toe/camber/caster), are controlled with stepper motors by a computer, to maximize efficiency in straight line AND maximize stability when making the tires screech.
Compromise is such a filthy concept.
ASE certified day-dream engineer
I'm making beautiful music's now, hear it and like me on Facebook!
Old 11-07-2009, 09:59 AM   #2 (permalink)
You need to do a lot more reading on suspension geometry.
Old 11-07-2009, 07:24 PM   #3 (permalink)
chop suey
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
I have read about proposed "active alignment" for heavy semi-trucks. I generally don't think the complexity is necessary on a light vehicle.
Old 11-07-2009, 08:19 PM   #4 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.85 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 28.75 mpg (US)
there's: toe, caster and camber...which do you plan on "adjusting" while driving?
...some roads have crowns, others don't and some have banks while others are flat.
2011 Chevrolet Cruze LTZ 1.4LT 6A
2009 Pontiac Vibe 1.8L/SIDI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
2003 Ford Focus ZX5 2.0L/Zetec 4A
1971 Dodge Charger 318 3A
1970½ Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
Old 11-07-2009, 08:58 PM   #5 (permalink)
You can get the alignment you want with out stepper motors which add costs , weight and complexity not to mention trying to sell a car fitted with them.
Complianced bushings do all that you need and keep the geometry where it should be.
Have a look at the "Weissach axle" from Porsche for an example.
I agree with TJTS1...do more reading about suspension geometry first and especially the forces involved.
Pete.
Old 11-09-2009, 12:37 PM   #6 (permalink)
Push - '03 Civic Si (Ep3)
90 day: 28.27 mpg (US)
I once saw a setup for an Ep3 (honda civic Si 2002-2005) when the top hats (the part that the strut and chassis touch at the top) were on this weird bar setup with the steering rack.
It gave the wheels more camber in a turn. (sort of like camber steering on motorcycles.) But I haven't heard anything for years.
Never heard of any suspension changing thing with motorized parts.
Old 11-09-2009, 09:33 PM   #7 (permalink)
Zero toe angle will give you the least amount of rolling resistance. Something near zero camber as well, and I don't think caster angle makes any real difference.
Zero static toe will tend to make your car wander a little bit, as the compliance in the bushings of the non-driven wheels will tend to lead to toe-out, which is dynamically unstable. If you've driven a car with toe-out, you probably know the feeling--the ability to change lanes without realizing it when you look down to change the radio station.
Static toe-out is even more squirrelly, as you get even more toe-out at speed.
Even with zero toe-out when the car is at speed makes for a car that tends to wander and hunt. It will like to follow any grooves or ruts in the road as well.
I don't think that having dynamic toe-change with speed will be worth the complexity. Having toe angles that change as the suspension compresses (presumably from the car going around a corner) can be; that's more or less what the aforementioned Weissach axle does. There are some other designs that have similar features, like the "passive rear steering" in the 1988 CRX Si models. Though it seems like that was done for less stability and more agility, unlike the Weissach axle which was designed for more stability.
-soD
Old 11-09-2009, 09:44 PM   #8 (permalink)
...beats walking...
...caster is "how far" the tire patch contacts the road AHEAD/BEHIND the projected pivot/axle.
...if the contact point is right under the pivot or behind it, you end up with the "grocery-cart" vibrations.
...if the contact point is too far forward, the tire edges will be scrubbed with every light turn, which definitely will kill FE (and the tires!).
Old 11-09-2009, 10:50 PM   #9 (permalink)
The original Insight has zero toe. I don't find its handling squirrely at all, but quite light & responsive. But I admit I do prefer & am used to sports car handling. The only problem is that it does tend to wander on grooved pavement, though I don't know whether that's due to the toe-in, the tires, or the light weight.
Old 11-09-2009, 11:21 PM   #10 (permalink)
I hate to indulge in pedantic semantics here...
Caster is the ANGLE formed by a line passing through the upper and lower suspension pivot points at the wheel hub when viewed from the side.
The distance between the point where this line meets the road surface and a vertical line drawn from the wheel centre to the centre of the contact patch (also when viewed from the side) is the "trail" distance.
The resultant side effects , resulting some times in "interesting" handling , mentioned above are both correct.
Pete.
DIY suspension generator / regenerator Daox EcoModding Central 60 08-09-2010 03:09 AM
Touchy subject - Big Bang Theory (not the religious argument) robchalmers General Efficiency Discussion 11 08-26-2009 06:27 PM
Variable air suspension Piwoslaw EcoModding Central 22 04-03-2009 11:52 PM
Metro Suspension Parts pint EcoModding Central 17 08-14-2008 11:38 AM
Suspension Dams on Production Cars Arminius Aerodynamics 19 08-13-2008 03:49 PM
