Old 07-06-2010, 03:19 PM   #1 (permalink)
Suzi - '94 Swift GA
90 day: 48.94 mpg (US)
Prius II - '05 Prius Package 6
90 day: 46.51 mpg (US)
Swap XFi engine for current I4?
I have been doing my own work on my car whenever possible. I have a 1994 Suzuki Swift with a 1.3L engine and a 5MT. I recently found a person within a couple hours of my house that has a 1994 Geo Metro XFi that he is parting out. It has 194,000 miles, which seems like a lot to me, and has me asking myself (now you) some questions...
  • How long do XFi engines tend to run? They said it is running perfectly, but it does have almost 200,000 on the engine.
  • What kind of FE boost would I see? 10%? 15%? Less/more? With the current I4 1.3L engine I routinely get 50mpg+ to work and back with nice weather. Would a swap to a I3 1.0L engine make that much of a difference?
  • What is the horsepower rating on the XFi? I am currently "boasting" 70HP and 70pounds of torque, I am sure the new engine would feel less peppy, especially on the hills...
  • I have around 172,000 on my engine, so I would probably keep running it until something happened, then make the change. Would it be a big job to swap then engines? I imagine they share most of the same mounting points, but my current engine has an extra cylinder, so would I need to acquire/fab mounting brackets?
  • How much does an XFi engine weigh? I would be transporting it in my car... which wouldn't be a problem if I didn't have to unload it alone.
  • I can also buy the transmission, worth the buy? My Swift already has the tallest gears... it would just be a spare I guess, unless I could mess with the gearing in my current transmission...
Thanks in advance!
Old 07-06-2010, 04:15 PM   #2 (permalink)
The Geo - '93 Metro
90 day: 45.16 mpg (US)
Who is the guy? Cause I could use a transmission...
Keep your 4 banger, unless you just want absolute MPGs... The added power is nice. You can load the engine by yourself, not problem. Tranny+engine is like 135lbs.
Old 07-06-2010, 04:37 PM   #3 (permalink)
Suzi - '94 Swift GA
He's over by Gadsden. FYI, he is selling Engine + Transmission + ECU, I haven't asked him about just Engine + ECU, or just transmission.
I think part of the problem is that since I started doing my own work, I notice more "sounds". The first one I noticed turned out to be the alternator, which I replaced... I guess the "back up engine" would just be nice in case anything happened.
I had planned on keeping the I4 until something happens (It could be another 100k miles), I would just feel better if I had a solid replacement engine waiting. My wife and I have been looking at minivans, because she doesn't know how long my Suzuki will last. If Suzi dies, I would get the Prius, and she would get a minivan. I figure having a replacement engine could head off the need for a minivan before we NEED one (big capitol cost + recurring cost (it uses more gas)). It's not just about the HUGE mpg potential, but about delaying the purchase of another vehicle.
Old 07-06-2010, 04:49 PM   #4 (permalink)
The Geo - '93 Metro
You can rebuild the I4 pretty easily...
Old 07-07-2010, 12:21 AM   #5 (permalink)
xfi clone .993 - '95 metro base
91 - '91 Metro
You would want the whole car for a swap. The clutch cable, speedo cable, axles, shift support, trans mount location are all different. I would drive the Swift and try to locate a spare 1.3 if I were you. imho I have done this swap in a 95.
Andy
The Following User Says Thank You to me and my metro For This Useful Post:
wyatt (07-07-2010)
Old 07-07-2010, 11:38 AM   #6 (permalink)
Suzi - '94 Swift GA
I had come to the conclusion that I may not want to store an engine for as long as it would be before needing it, and not knowing what my living situation will be when our house sells, I didn't want to pay for storage on it either. I am glad to hear that my decision was a good one based on the number of parts that would be needed... I could get the whole car, but I don't know how storing a whole car would be better than storing an engine... Thanks for the input!
Wyatt
1.0l i3, 1.3l i4, engine swap, swift, xfi
Blackfly XFi? Cam swap! Update: swap completed MetroMPG EcoModding Central 19 06-04-2011 06:16 PM
Mer-Chevy Project: Biofuel 40mpg Pickup bennelson EcoModding Central 128 07-27-2010 06:15 PM
Engine Insulation GdB EcoModding Central 5 11-30-2009 02:05 AM
Coasting experiment: engine on VS engine off on a fixed route = 12.9% gain MetroMPG Hypermiling / EcoDriver's Ed 6 02-22-2008 08:38 AM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
