Swapping a TDI engine into a 1st gen Insight
I've decided to swap a 1.9 liter VW TDI engine into a Honda Insight.
This project is just getting started since I only have the donor vehicle right now (98 Beetle TDI). To my knowledge, the TDI swap has only been attempted once before and it was with a 1.2 liter Lupo engine that can't easily be found where I live (America). I'll be using the venerable "ALH" engine which is found in the US Spec Golf, Jetta, and New Beetle from the 98-03 time frame. I'm currently looking for a 1st gen Insight with a bad battery/IMA/engine that can be used for this swap. I've started a blog to update as the project moves along. Keep in mind this won't be a quick swap. I'm pretty busy but also pretty anal so progress will be slow. I'll post here with updates as they occur! In the meantime, feel free to check out my blog: www.hondatdi.com Thanks! |
You can order stuff from overseas moderately easy these days, you just have to have bank $5k-$12k to make it happen. |
I look forward to this build.
A TDI would fit easier into a CRX. In my state such a swap in to a 1996 or newer car would not pass the OBD II emissions test, thus could no be licensed.
I'm an engineer with one of my best friends helping me do the fabrication. I am confident we can make it work... it may just take awhile since we're both really busy. Thanks for the support! |
I'm obviously not condoning skipping out on emissions regulations (especially on a forum like this!!) but there are times when they simply don't make sense. I plan to have all emissions equipment functioning as intended on the Honda TDI. We plan to have the OBD II working so we can use a VAG-com on the car as well... |
Ever wonder how fast a 98 Beetle TDI is bone stock?
Turns out it's not as fast as it feels... watch the video on my site below for some numbers. » Beetle Performance Testing The Honda TDI Project :turtle: |
Wow, I would not have expected it to be THAT slow! What is the weight difference between the Insight and beetle? I expect not much?
According to both manufacturers... the Beetle is exactly 900 pounds heavier than the Insight :eek:
