Old 08-23-2008, 07:32 PM   #11 (permalink)
Oden - '00 Frontier Crew Cab
Pickups
90 day: 21.99 mpg (US)
Malinda(WJ) - '03 Grand Cherokee Limited
90 day: 15.28 mpg (US)
Nerdcycle - '81 CM400E
Motorcycle
90 day: 53.8 mpg (US)
Bumblebee - '08 V3
Motorcycle
90 day: 69.17 mpg (US)
Ok, here is the quote from the manual and you guys tell me what it means.
"Engine Oil Recommendation
USE HONDA 4-STROKE OIL OR AN EQUIVALENT.
Use only high detergent, premium quality motor oil certified to meet or exceed US automobile manufacturers' requirements for Service Classification SE.
Motor oils intended for Service SE will show this designation on the container.
The use of special oil additives is unnecessary and will only increase operating expenses.
CAUTION: Engine oil is a major factor affecting the performance and service life of the engine. Non-detergent, vegetable, or castor based racing oils, are not recommended."
Then it has a chart showing SAE 10W-30 is good for when the average temperature in my riding area is between -5F and 90F and SAE 10W-40 is good for -5F and up.
So I get the detergent thing, but what is 4-stroke oil or an equivalent? Cars are 4-stroke. What should I put in this thing for the best mileage without spending $50 on oil? The 0W-30 I got from Wal-Mart is about $30/5 quarts, so using that would cost me about $15.
Old 08-23-2008, 09:57 PM   #12 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
stay away from "efficiency" or friction modifiers. Look at the bottle for an sf or an sg.
Honda Nighthawk Specs
Recommended Oil Honda 4-stroke oil or equivalent.
API SF or SG, SAE 10W-40
5 � F to 110 � F SAE 10W-40
5 � F to 90 � F SAE 10W-30
Old 08-25-2008, 11:38 AM   #13 (permalink)
EP3 - '03 Civic Si
90 day: 31.73 mpg (US)
Scooter - '93 Elite 80
90 day: 74.87 mpg (US)
Ape - '07 Sportcity 250ie
90 day: 66.97 mpg (US)
Typically if it says 4-stroke it means motorcycle/powersports oil. Honda 4-stroke is used for honda motorcycles and powersports and is made for use with wet-clutches. If it just says motor oil it's typically for a car. Amsoil synthetic was only about 8 bucks a quart for me, how much oil does your bike take? You can try normal oil, but i have a feeling you will feel your clutch start to slip.
Effect of gear oil viscosity on transmission efficiency (Metro owners take note) MetroMPG EcoModding Central 36 06-11-2011 04:04 AM
Oil change recommendations? rjacob EcoModding Central 48 08-02-2010 05:04 PM
Synthetic Oil save more gas? xbUser EcoModding Central 22 08-02-2008 05:23 PM
Synthetic Motor Oil Change Interval trikkonceptz Off-Topic Tech 15 06-11-2008 10:08 PM
Low viscosity and/or synthetic gear oil? Dane-ger EcoModding Central 7 01-13-2008 07:58 AM
