Old 05-28-2017, 11:11 PM   #101 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
90 day: 20.99 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
90 day: 19.68 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
90 day: 20.6 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
90 day: 21.28 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
90 day: 20.56 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
90 day: 20.54 mpg (US)
BZP T-100 current (2017) - '98 Toyota T-100 SR5
90 day: 19.38 mpg (US)
Send a message via ICQ to BamZipPow Send a message via AIM to BamZipPow Send a message via MSN to BamZipPow Send a message via Yahoo to BamZipPow
Wink
Got some measurements off of Dark Aero's belly pan to calculate the exit angle.
Length of belly from the end of the diffuser to the end of Dark Aero = 76"
Distance from ground to the bottom of Dark Aero end = 16"
Exit angle from the rear diffuser to the end of Dark Aero = 3.95 degrees.
Overall length = 288".
The Following User Says Thank You to BamZipPow For This Useful Post:
aerohead (06-03-2017)
Old 06-03-2017, 01:26 PM   #102 (permalink)
meetup
Thanks again for the meal Bam,and look at the upgrades.Hope you guys got home okay.
BamZipPow (06-06-2017)
Old 06-06-2017, 02:15 AM   #103 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Rear diffuser lost the bolts on the right front hinge and was flapping a little bit on the way home. I guess it screwed up my numbers a bit.
Got the bolts replaced and bolted the hinge back in. A quick run into Houston in the afternoon was indicating around 25mpg on the Ultragauge.
aerohead (06-10-2017)
Old 06-06-2017, 04:16 AM   #104 (permalink)
Did you use Nylock or split washers this time?
BamZipPow (06-10-2017)
Old 06-10-2017, 07:26 PM   #105 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Wink
I had split lock washers on the bolts last time. I've decided to use some thread locker this time.
The Following 2 Users Say Thank You to BamZipPow For This Useful Post:
aerohead (06-17-2017), freebeard (06-10-2017)
Old 06-10-2017, 07:54 PM   #106 (permalink)
I went looking to see what that was and found this:
engineerdog.com/...10-tricks-engineers-need-to-know-about-fasteners/
aerohead (06-17-2017), BamZipPow (06-10-2017)
Old 07-05-2017, 12:43 PM   #107 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Updated the rear belly pan with bigger hinges and added supports to keep it from flexing. I didn't do that before and it was flexing during my run up North.
Best mpg on the run West has been an indicated 26.9mpg.
aerohead (07-08-2017)
Old 08-02-2017, 10:42 PM   #108 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Wink
Finally had some time to cover up the crossbeams with the rubber baseboard strips. Zip tied them to the slotted angle about every 8" or so on both angles fer both beams. I'll have to make a run and see if it makes a difference or not.
aerohead (08-05-2017), slowmover (08-04-2017)
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
