Old 05-18-2010, 12:01 AM   #1 (permalink)
81 civic wagon - '81 Civic Wagon
90 day: 30.31 mpg (US)
Tachometer or Vacuum Gauge?
I am trying to decide between getting a Vacuum Gauge or a Tachometer as my car has neither. I have a 1981 Honda Civic Wagon so a Scan Gauge II is out of the question.
Which would give me better feedback for the purpose of improving FE?
Which would have the most impact?
Old 05-18-2010, 07:20 AM   #2 (permalink)
Vulcan - '05 Vulcan 500 LTD
90 day: 60.08 mpg (US)
Mag Pearl - '011 Fiesta SE Hatch
90 day: 45.91 mpg (US)
Knowing your gear ratios, tire diameter and differential ratio would allow you to calculate RPM in gear.
I would go with the vacuum guage, since knowing the vacuum reading is probably the single most important piece of information for getting best mileage as well as diagnosing any issues you may have mechanically.
I keep thinking about putting one in my 94 VX so I can keep it at the 6 inches lean burn threshold, but after 29,000 miles I can feel the transition fairly well, and I doubt if I would improve my mileage beyond it's current level since most of my driving is 50-65 MPH average speeds in the VX.
regards
Mech
Old 05-18-2010, 03:41 PM   #3 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
+1 on the vacuum gauge.
...did any version of that model Honda come with a tach? if yes, consider finding a replacement at a junkyard...wiring is (usually) already there, just not connected to anything.
2011 Chevrolet Cruze LTZ 1.4LT 6A
2009 Pontiac Vibe 1.8L/SFI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
2003 Ford Focus ZX5 2.0L/Zetec 4A
1971 Dodge Charger 318 3A
1970½ Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
Old 05-22-2010, 11:18 AM   #4 (permalink)
I have to start over?
Big inefficient truck - '94 Ram 2500
90 day: 12.1 mpg (US)
Honda Civic - '84 Civic DX Hatchback
That's exactly what I did. It was as simple as getting the instrument cluster (with gauges and tach, I was replacing dummy lights and a HUGE gas gauge), pulling out the old one, and plugging the same connectors into the back. I had to calibrate the tach, though, because it came from a V6 and I have an I4.
Who says you can't have both?
Old 05-22-2010, 05:43 PM   #5 (permalink)
...beats walking...
...my 1984 Honda DX didn't have a tachometer, so I simply got a dash from an '84 model that did, and installed it into my car -- everyting worked fine!
gauge, tachometer, vacuum
10-minute Accord vacuum gauge "install" Clev DIY / How-to 7 09-10-2010 03:53 AM
Vacuum gauge: all or nothing! elhigh Instrumentation 2 04-23-2009 08:57 PM
Tach & Vacuum Gauge Installed midnight rumbler Success Stories 8 01-01-2009 01:33 PM
no vacuum for vacuum gauge? modmonster Instrumentation 2 11-07-2008 07:40 PM
Vacuum gauge problems :( DifferentPointofView Instrumentation 3 05-14-2008 11:04 PM
