Old 03-04-2010, 11:17 PM   #21 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Zombie Insight - '00 Insight MT
90 day: 62.82 mpg (US)
It looks like you were only able to reduce your trailing wake area by about 20-25%, so a 10% reduction in drag (for a slightly smaller % reduction in highway fuel economy) would not be surprising.
In an ideal world, you'd taper the sides inward for a larger reduction in rear area. In reality, that's difficult to execute with plywood, and it's nice to have the bedrails under your aero cap. In a very ideal world, you'd taper the sides of the bed inwards, too.
You can use the same template as you did for the side view, but line up the ground plane of the template with the center line of the truck. If your shape curves inward from both sides and from the top, you can get away with sharper shapes than the template suggests. How much sharper? I do not believe anyone here can tell you (except to recommend you imitate the EV1 and Honda IMAS), so you'd be flirting with flow seperation.
But back to reality. You have a classy looking cap, and I like the overhang. If you want further drag reduction, you'll need to find room for more reduction in trailing area. You've already plucked the low-hanging fruit in that department.
Old 03-05-2010, 09:58 AM   #22 (permalink)
Quest for a 400 mile tank
mjboks's Avatar
Adventure Truck - '07 Tacoma Double cab V6 TRD 4wd offroad
90 day: 19.26 mpg (US)
Commuter Bicycle - '94 mountain bike
template overlay
I took your image from the other thread and overlaid the template. Not sure if it's the angle of the camera or not but it looks like your cap is a bit on the conservative side... better than too steep and getting separation.
Here's the image with a couple simple lines drawn in if you did a tailgate extension.
Old 03-05-2010, 01:04 PM   #23 (permalink)
Recreation Engineer
KamperBob's Avatar
Black Stallion - '02 Tundra 4WD xCab
Half Pint - '06 XT225
Is the back open or closed?
Cheers
KB
Old 03-05-2010, 01:37 PM   #24 (permalink)
old red taco - '02 tacoma regular cab
90 day: 29.49 mpg (US)
the truck is slightly lower in the front in the picture if you look at the black bed liner under the cap compared to the template bottom. if the truck is perfectly flat the template matches up pretty close.
kamperbob the tailgate was closed during the tests. not sure if that is what you are asking. but the back of the cap has a piece of plywood on it.
i think i should do what metrompg said and move on to the under side of the truck. i think that my results showed that the big mpg loses as speed increased tells me that trucks have very bad aerodynamics and that if i clean up the bottom i should see less loses as speed increases.
since the test i have been more aware of wind conditions and yesterday i was driving from Tampa to Melbourne and i had a 10-15 mph tail wind and i was averaging over 30 mpg on the scangauge at 65 mph. which makes sense because i was getting around 30 mpg at 55mph on my tests
Old 03-05-2010, 02:02 PM   #25 (permalink)
Recreation Engineer
KamperBob's Avatar
Good. I meant the cap not the tailgate. (I was wondering about possible reduced pressure *inside* the cap (vacuum effect) acting on large vertical surfaces, but if the cap was closed that should not be a factor.)
Cheers
KB
Old 03-05-2010, 02:09 PM   #26 (permalink)
mjboks's Avatar
Thought that might be the case. The bed rail shows a bit of a downward angle in the image.
Old 03-11-2010, 03:55 PM   #27 (permalink)
i just filled up my gas tank after doing my ABA test and the scangauge was not accurate on the fuel consumption on my truck. the scangauge though i used 13.6 gallons and i only used 12.96 gallons. so the scangauge was figuring the mpg 4.94% low (i just got it back from repair) i also thought the mpg's were a little low for my truck. so the actual mpg's for the test would be
A 28.045
B 27.048
A 28.333
gain 1.142
gain percentages still stay the same as metrompg stated
Old 03-12-2010, 09:56 AM   #28 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 Golf
90 day: 51.68 mpg (US)
On another thread Aerohead suggested putting ballast in the car to simulate driver and passenger weight before determining the correct angle for a boattail from the template. As I recall, you said you need to haul things in your truck bed from time to time. I had this thought that it may be better to be conservative in your angles (as I think you are) than to get them just right and have it too steep as soon as you put a load in the bed of the truck.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
How to properly test modifications (AKA: don't believe every MPG claim you read) MetroMPG EcoModding Central 71 05-09-2012 02:44 PM
Aerocap for a Tacoma Pickup? mjboks Aerodynamics 83 02-26-2010 03:36 PM
issue with the aba test TheDon EcoModding Central 2 06-17-2008 06:18 PM
