Old 11-24-2011, 08:15 PM   #1 (permalink)
HydroJim's Avatar
taller new tires?
I'm going to be getting new tires soon and was wondering if anyone had any input on getting taller tires. The stock size is 195/60R15, but the previous owner had 195/65R15 put on the car. The tread is almost gone so it's time to get new ones. I planned on the getting LRR tires but I'm wondering if I should go with the stock size or go to next size up which is currently on the car.
On the tires I'm looking at, its a difference of 27 revs per mile. I guess there is no reason not to go to taller tires, I'm just checking with the fuel economy experts on here.
My car is a 2000 Ford Focus ZX3.
Old 11-24-2011, 08:27 PM   #2 (permalink)
V8 guy
Sub - '84 Suburban C10
Pickups
camaro - '85 Camaro Z28
I went with 2 inch taller tires that were nearly 20 pounds heavier with my suburban and could detect no loss in fuel economy.
I say go big.
The skinnier smaller tire fad has not delivered.
1984 chevy suburban, custom made 6.5L high compression diesel.
New engine is in and should be good for 29mpg highway.
1985 chevy camaro mostly stock.
Old 11-25-2011, 06:03 AM   #3 (permalink)
F8L
F8L's 2012 Prius - '012 Prius Three with Solar Roof
As we allow know, the larger diameter tire will reduce rpm at cruising speed. Weight differ should be negligible. I would make sure you stay at the same width so you don't increase friction, get a LRR tire like the Ecopia EP100/Ep422, Energy Saver A/S, dB Super E-Spec or Nokian i3, etc. and ensure you register the speedometer difference so you don't mistake a mpg due to traveling slower/faster than you think you are.
Old 11-25-2011, 10:35 AM   #4 (permalink)
Pishtaco
SentraSE-R's Avatar
Clean Green Toaster Machine - '06 xB
90 day: 45.81 mpg (US)
Tall tire test.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
Mean Green Toaster Machine
49.4 mpg avg over 30,375 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
45.8 mpg over 2235 miles, 164% of '08 EPA
Old 11-26-2011, 12:09 PM   #5 (permalink)
sc1 - '98 sc1
90 day: 46.37 mpg (US)
Tour bike - '011 Carp line Tour
Go with the taller tires for MPG, 205/75R15 or /70, 44 psi, if they clear suspension. For lower RR and snow use 185/65R15. Same OD as stock tire.
- Tony
