Old 12-09-2008, 03:55 PM   #31 (permalink)
2k2Prot5 - '02 Protege5
90 day: 33.82 mpg (US)
Haha... sorry if my shiny new sports car is out of your expertise...I just read that article... interesting... very easy... only question is, what does he mean by "unstake the bolts"? Are they bolts with a pin through them or something?
Did he swap in a different ratio in that article or just replace a worn out gear?
Old 12-09-2008, 03:59 PM   #32 (permalink)
Mazda Familia - Wikipedia, the free encyclopedia
OH MY GOD! My car has a deisel option somewhere else in the world! Hm, i wonder what the gearing is like on THAT guy
Old 12-09-2008, 04:02 PM   #33 (permalink)
It leads me to believe that there is either a shear pin, or key or some such that holds the gear retaining nuts in place. I think he just replaced 5th with the same gear, but the procedure would be the same whether or not the ratio was changed.
BTW, I refreshed my memory and the F5M is the earlier of the F-series transmissions, while the F25M is the latter version. According to the second link, it doesn't seem to depend on the engine being SOHC, or DOHC. Also the A26M-R is a manual even though there is an 'A' in the name.
The A26M-R might just work in your Protege5 MazdaMatt, IIRC the MS-Protege was a '03 model year, so that would be good for you. I'd sure love to shoehorn that critter into my MX-3 though!
*Time period is from 1 January 2006 - 1 March 2007*
Old 12-09-2008, 05:57 PM   #34 (permalink)
Oh yeah, i forgot to mention that I have a 2.0 L FS-DE DOHC I4. Funny how just 2 years ago I was considering changing to the FS-DET (turbo), and now i'm considering making the gears taller... my how things change.
Old 12-09-2008, 07:01 PM   #35 (permalink)
Now on two wheels!
[SOLD] Highway Warrior - '00 Protege LX 1.6L Manual
90 day: 35.93 mpg (US)
Basic Miata - '06 Miata Touring
90 day: 31.65 mpg (US)
Send a message via AIM to 1337
Originally Posted by Volones View Post
1337, you have a Mazda F5M, or F25M transmission in your protege. The difference is the F5M came with the SOHC engine and the F25M came with the DOHC engine. I believe you can swap the 5th gear from a Mazda 626, but that may be the G-series tranny instead of the F-series. I have the F25M in my MX-3, and plan on swapping in the transmission from a 1.5L SOHC Protege when I can afford to. The individual gears are the same, but the final drive is 3.4:1 instead of 4.1:1
I'll try to find the link I have for the Protege transmission info in a few minutes.
Cheers,
Vol
Edit//
Here's a link regarding swapping 5th gear in a Mazda F-series transmission
MX-3.com - View topic - 5th gear replacement (F-series)
Hopefully, you won't need to be a member, and even though this isn't your car, the transmissions are the same for this procedure.
Best of luck!
Here's the link I was looking for...
Protegé FAQ - Transmission Info
Lots of great info here. Anything with an 'M' is a manual, anything with an 'A' is an automatic (in case you get easily confused like I do). Have fun!
Volones,
Thanks for the help. I'm pretty sure I have the F25M, because the 1.6L is DOHC. (Unless someone knows of an SOHC version of the 1.6... if you trust Wikipedia, there is only a DOHC 1.6 Mazda Familia - Wikipedia, the free encyclopedia )
Protege FAQ gives a table of the Protege models that come with the F25M, but does anyone know what other cars (probe? escort?) also use F25M or at least the same gear design as the F25M?
Sidenote: Less than a year before I bought my Protege, the previous owner had the transmission replaced at a shop (the owner paid $2500 for a new clutch and trans on a $3000 car). Is there a chance the shop could have installed a non-F25M transmission?
2006 Miata Touring 5MT
2006 VW Jetta TDI 6AT (Sold to buy Miata)
2000 Mazda Protege 1.6L 5MT
2002 Mercedes C230 Coupe 5AT (Water damage, totaled)
Old 12-10-2008, 10:16 AM   #36 (permalink)
Originally Posted by 1337 View Post
Volones,
Yes, the '92-'93 model years Mazda MX-3RS came with a SOHC B6 engine. Check out this wiki page about the Mazda B-series engines...
Mazda B engine - Wikipedia, the free encyclopedia
Yes, the previous article explains which cars used which engine, so that should help.
Yes again. It is common for people in the MX-3 community to swap their F-series transmission for a G-series one when they add a turbo. The F-series has trouble when the engine can produce over ~200ft/lbs torque and has a tendency to shred gears, especially 3rd and crack cases. The G-series has a more robust case and stronger gearset, so that's why they use them. Evidently it's a pretty straight forward swap too.
Old 01-17-2009, 10:16 PM   #37 (permalink)
Now on two wheels!
I haven't touched the Protege for a month, since I left it at college while I went home for break. Anyway, I did a little more research on what 5th gears I could put in my Protege.
To covert from engine/model (eg. '00 Protege 1.6L) year info to a Mazdaspeak powertrain (eg. ZM-DE), these articles are useful:
Mazda Z engine - Wikipedia, the free encyclopedia
In Mazdaspeak, my engine is the ZM-DE engine,
Then look at Protege FAQ's article on transmissions...
According to Protege FAQ, my ZM-DE has an F25M-R transmission. This particular F25M-R has a .775 5th gear and a final drive of 3.850.
There are two American market Proteges with an F25M-R transmission and taller 5th gears:
'92-'94 Protege with B8-ME (1.8L 16V SOHC engine)
5th gear: .731 Final drive: 3.619
'92-'94 MX-3 with B6-E (1.6L 16V SOHC engine)
5th gear: .731 Final drive: 4.05
I think the easiest thing to do would be to find a '92-'94 1.8L SOHC Protege and to swap the 5th gear into my Protege. I don't remember the exact number, but I think my Protege does 3000 rpm at 65mph. The new 5th gear would be 3000*(.731/.775) = 2830 rpm.
Now, I'm debating...is it worth my time to do a gear swap, just to lower my engine speed by 170 rpm?
Old 01-18-2009, 02:21 PM   #38 (permalink)
Big Dave's Avatar
The Red Baron - '00 F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Impala SS
90 day: 21.03 mpg (US)
A taller gear did wonders for my truck. Replacing 3.73s with 3.08s gained me 3 MPH on a 20 MPG truck. Now I go down the road turning 1700 RPM @ 70 MPH.
Gotta watch taller gears if your vehicle is an automatic. Less flow through the cooler will lead to spectacular (parts and ATF scattered down the road) automatic transmission failures. If you have a manual, you are golden.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Hard Tonneau and Rugged Air Dam
Old 01-18-2009, 07:36 PM   #39 (permalink)
1988 Ford Escort Pony - '88 Escort Pony
90 day: 39.88 mpg (US)
1997 Ford Escort Station Wagon - '97 Escort LX Station Wagon
90 day: 39.4 mpg (US)
Lil Red - '88 Escort GL
90 day: 32.23 mpg (US)
The next set of tires I put on my '88 Escort are going to be over sized, probably going from a 185-70-13 to a 185-75-14 which will be an increase of 7.5%. I should get some noticeable increase in FE and don't have to get my hands greasy.
Old 01-19-2009, 12:24 AM   #40 (permalink)
Big Dave's Avatar
A lot of guys in the pickup truck community have tried larger diameter tires and the empirical result is always the same: Larger diameter tires result in lower MPG.
Wheel and tires are "flywheels" that have to be accelerated everytime you pull away from a stop. The energy stored can be tapped to a limited extent by a skilled hypermiler, but mostly gets wasted.
Forget the tires and get taller gears.
4" Slam
taller gearing
Saturn S-Series 5th Gear Swap cfg83 EcoModding Central 57 12-31-2011 10:11 PM
Met an unhappy Aveo owner today MetroMPG General Efficiency Discussion 24 10-10-2010 08:03 AM
