Old 01-08-2013, 02:43 AM   #21 (permalink)
I want a 3-speed manual with a direct drive top gear- fewer gear meshes, fewer spinning parts, less friction. I skip shift most of the time anyway, combined with short-shifting and the engine doesn't have to cope with much of an rpm spread.
Doesn't sound unreasonable at all, but I'd rather get an overdrive 4-speed...
Old 01-08-2013, 03:11 AM   #22 (permalink)
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
Part of the point is to avoid overdrive, which from a power transmitting POV isn't as good as a direct drive with a suitably tall final drive.
Old 01-08-2013, 03:13 AM   #23 (permalink)
Indeed
Old 01-08-2013, 05:43 PM   #24 (permalink)
Old Mechanic -- I always filter everything through the prism of would it work in an old Beetle. What I would like is an older [non-hypoid] Type I transaxle with a hydraulic clutch:
And a replacement nose cone that replaces the shift rods with an hydraulic actuated, microprocessor controlled mechanism.
Paddle shifter built into the stock horn ring.
What are the odds?
Old 01-09-2013, 02:49 AM   #25 (permalink)
Paddle-shifters in a Beetle (or any other rear-engined Volkswagen) would be nice.
Old 01-09-2013, 03:52 AM   #26 (permalink)
I like that the install would be total stealth—just a missing shift lever.
I saw a Karmann Ghia coupe at the NW Bug Run that had a mid-engine installation, and a pneumatic shifter that ran off 2ea 1500psi air tanks. He only had to refill "about once a month."
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
