Old 12-08-2010, 08:17 AM   #1 (permalink)
aero guerrilla
Piwoslaw's Avatar
Svietlana - '05 307 SW
Diesel
90 day: 55.98 mpg (US)
Tapping into signal wires
What is the best (ie safest) way to tap into a signal wire? There are a few sensors that I'd like to monitor, the "signal" is usually just the voltage (eg 0V=open, 5V=closed, etc). Since taking the plug or socket apart is too hard (if at all possible), I have to somehow get into the wires. I can see three options:
  1. Cut the wire, then solder it back together with a third wire for monitoring,
  2. Same as above, but without cutting, only stripping some of the insulation off,
  3. Insert a metal sewing needle through the insulation and solder the monitor wire to the needle.
Since I want to monitor the signal only for a short period of time, I would like to be as non-invasive as possible. Options #1 and #2 may lead to problems with corrosion in the future, so is #3 the best?
Piwoslaw's Peugeot 307sw modding thread
Old 12-08-2010, 08:26 AM   #2 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
If its temporary, I'd do #3. Put some electrical tape over it after you're done just to be safe.
The Following User Says Thank You to Daox For This Useful Post:
Piwoslaw (12-09-2010)
Old 12-08-2010, 08:27 AM   #3 (permalink)
JasonG's Avatar
1 Ton - '94 C3500
90 day: 19.7 mpg (US)
Big White Brick - '03 Express Van
90 day: 15.19 mpg (US)
I'm not sure if they are available in Poland, but here the auto parts stores carry splice taps.
they clamp on to the wire and provide a 3rd port for a new wire.
when removed the insulation only has a small nick like your needle idea.
example: BWD CT617A - Terminal | O'Reilly Auto Parts
Support Bennelson !
I can't understand why my MPG's are so low..........
16000lb, 41' Toy Haulers are rough on FE!
The Following User Says Thank You to JasonG For This Useful Post:
Old 12-08-2010, 08:50 AM   #4 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
solder a lead to the pin, then stick it into the wire. Wipe a little silicone sealant over the hole(s) when you take the pin out if so inclined to restrict further oxidation.
The Following User Says Thank You to dcb For This Useful Post:
Old 12-08-2010, 06:00 PM   #5 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Zombie Insight - '00 Insight MT
90 day: 62.82 mpg (US)
If you can get at the ends of your wire harnesses (e.g. where they enter the ECU), you can get a narrow probe in there without piercing the insulation.
The Following User Says Thank You to RobertSmalls For This Useful Post:
Old 12-08-2010, 10:07 PM   #6 (permalink)
Apparently what you are seeking is a way to read the voltage of the wires by piercing but not cutting the insulation. It's called pick probing. You will need a few, very sharp dental instruments that can pierce through the insulation of the wire just enough to make contact with the wire. The handle end of the instrument will be attached by an alligator clip to the meter you are using. When you remove your pick, the pin prick in the insulation will be so slight as to need no remediation to the wire or its insulation
(I've only been using this technique for 40 years. If you find it useful a 'thank you' would be appreciated.)
The Following User Says Thank You to Thymeclock For This Useful Post:
Old 12-09-2010, 01:58 AM   #7 (permalink)
aero guerrilla
Piwoslaw's Avatar
Diesel
That's the problem - where I could, I took the plug/socket apart and added a thin wire to the pin. But in many cases the harness is waterproofed and can't be taken apart without breaking something. I've tried, but too many layers of plastic and silicone.
Dental instruments (chill runs down spine)...
Thanks to everyone
Old 12-11-2010, 07:03 PM   #8 (permalink)
you could get another connector, and solder pins on the end to fit into the original connector, splicing off a wire as in #1. then when you're done, just unplug your "piggyback" setup, and plug the original connector back in. sort of a man-in-the-middle type setup, and no worries about corrosion/broken wires with method #3. just a thought.
Old 12-11-2010, 11:31 PM   #9 (permalink)
Method #3 will neither cause corrosion, nor broken wires. But you need something a bit heftier than a pin, and a sharp, fine dental instrument is just right for the job of pick probing.
Old 12-12-2010, 01:24 PM   #10 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
+1 for method #3, the 'pin-thru-insulation.'
...and a single wrapping of self-vulcanizing tape seals everthing up tight.
MPGuino for Audi rmccomiskie OpenGauge / MPGuino FE computer 40 05-22-2011 09:18 PM
Kill switch signal cutting options Daox EcoModding Central 19 01-28-2011 02:25 PM
What does an injector signal look like? mhopeng OpenGauge / MPGuino FE computer 10 12-28-2009 01:28 PM
VSS signal acceptable voltages? bestclimb EcoModding Central 1 11-27-2009 09:05 AM
Tapping into wires skyl4rk EcoModding Central 10 03-12-2009 11:28 AM
