Old 08-18-2011, 06:09 PM   #111 (permalink)
graydonengineering's Avatar
Frontier 2wd 2.4L 5 speed - '98 Frontier XE
90 day: 27.72 mpg (US)
It's almost an open-wheeled vehicle! The entire sides would be turbulence between the tire faces,certainly negating some of the 'positive' features.
Manly though,like a pop-up castration-mine.
Yea, the body of the car has a very nice profile but the side of the car is a aero train wreck. Not sure what the deal is with the rear wheel wells, I'm guessing there is a small radiator on eather side so the open face surves as the "grill".
-Miles
Best 15-mile commute city/highway mix: 37.7 mpg
Best tank so far: 31 mpg
Old 08-18-2011, 06:11 PM   #112 (permalink)
pivoting
For the super high mileage competitions, prone driver position is outlawed. Probably here too.
I'm sure they thought of pivoting boots. Question is why they didn't do it.
That's a head scratcher for sure! The Honda Dream-2 car had the turning wheels on lazy-susans which allowed an airtight, minimum frontal area, along with wide articulation of the wheels.They could have just ripped Honda off.
Old 08-20-2011, 12:27 AM   #113 (permalink)
Bicycle Bob's Avatar
Appliance White - '93 Metro 4-Dr. Auto
Last 3: 42.35 mpg (US)
Stealth RV - '91 Sprint Base
[QUOTE=euromodder;256790]I doubt they'd have rear wheel steering, which is fine for low speed forklifting but a bear to handle at high speed - these vehicles can hit 60mph / 100kph.
Rear wheel steering works fine for the Dymaxion car, and many others since. The key is to use the same geometry as a regular car running in reverse, but to add a steering damper. That way, it wants to go straight. The only real disadvantage is the extra time and road width needed for maneuvers. You have to swing the back end to steer the front.
Old 02-26-2012, 10:29 AM   #114 (permalink)
Cd
Ultimate Fail
Cd's Avatar
I know that this is image isn't correctly positioned, but it gives some idea of what goes through my head every time i see a Honda Fit.
I thought i would Fit it to the the template backwards and ...wow ...pretty close Fit !
"You don't fail until you give up. You learn, and move on." - Christ
" Hypermiling is not going slow, it's driving with more intelligence." - UFO
Last edited by Cd; 02-26-2012 at 01:59 PM.. Reason: I guess you cant use Flickr to hotlink FAIL !
Old 02-26-2012, 04:19 PM   #115 (permalink)
Gen II Prianista
Rokeby's Avatar
Re: the Lotus 2002 concept car in post #106:
I don't believe that the front of the vehicle is to the right as has been supposed.
Granted, whichever end goes first, airflow along the sides is going to be a mess.
For reasons I can't comprehend, ~85% percent of Inter-web photos are from this angle.
I'm betting the front is the end to the left. Here's what it looks like:
It's even got headlights of a sort!
FWIW, here's a link to the best set of pictures that I could find: Concept Carz
I believe that the rearview camera stalks have been moved aft of the doors to
cleanup the A-pillar.
Old 02-26-2012, 04:25 PM   #116 (permalink)
Cd
Ultimate Fail
Cd's Avatar
I remember reading that Ferrari mounted their mirrors high on the Testarossa to reduce A pillar drag.
I guess it didn't help much, since I have never seen that configuration again.
Old 02-27-2012, 04:53 AM   #117 (permalink)
aero guerrilla
Piwoslaw's Avatar
Svietlana - '05 307 SW
Diesel
90 day: 55.98 mpg (US)
I sometimes wonder if the sole purpose of that Lexus wasn't so that Tom Cruise could have a futuristic ride in Minority Report Anyhow, that car (ie the rolling mock-up used for filming) is on sale, if anyone is interested in coastdown testing it
IMO the mirrors (on the prototype, not movie, version) are mounted high to get a view of more than just the rear wheels:
More pics here.
Piwoslaw's Peugeot 307sw modding thread
The Following User Says Thank You to Piwoslaw For This Useful Post:
Cd (02-28-2012)
Index of Phil Knox Aerodynamics Seminars & Mod-data lists TestDrive Aerodynamics 12 07-21-2011 01:14 AM
Hexagonal Dimples as a way to improve aerodynamics Palionu Aerodynamics 29 10-27-2009 12:39 AM
Aerodynamics Seminar #1 - by Phil Knox MetroMPG Aerodynamics 5 07-12-2008 04:12 AM
Aerodynamics Seminar # 5 - by Phil Knox MetroMPG Aerodynamics 4 01-29-2008 01:41 PM
Aerodynamics Seminar # 4 - by Phil Knox MetroMPG Aerodynamics 0 01-28-2008 08:36 PM
