Old 01-14-2011, 10:34 AM   #1 (permalink)
Sweetie - '011 Sonata GLS
90 day: 37.06 mpg (US)
HONKR - '94 KLX686
90 day: 59.94 mpg (US)
Tell me how well
a Scangauge will work for me....
I E-ON-C every chance, use cruise when applicable, turn off ignition at long lights and limit my top speed on the highway.
I have read that the Scangauge is better for 'Load' driving and wonder how well that will work for me since I coast as much as possible.
Just basically wondering if there is a better (as or more accurate with easier setup) instrument out there.
My factory MPG average gauge is close to 10% off at all times and reads on the high side.
Old 01-14-2011, 10:37 AM   #2 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
The scangauge should work just fine for you. You should be able to dial it in within a couple percent. Lots of people here use engine on and engine off coasting and the SG monitors both pretty well. The only thing the SG isn't very good with is diesels and lean burn engines. Even then, if you drive consistent and your commute is consistent I'd think the SG would be able to be dialed in pretty well.
Old 01-14-2011, 12:19 PM   #3 (permalink)
Pishtaco
SentraSE-R's Avatar
Clean Green Toaster Machine - '06 xB
90 day: 45.81 mpg (US)
I agree. A Scangauge should work fine for you. An Ultragauge works just as well, with much easier and faster setup, for less than half the price.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
Mean Green Toaster Machine
49.4 mpg avg over 30,375 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
45.8 mpg over 2235 miles, 164% of '08 EPA
