Old 12-11-2008, 04:25 PM   #51 (permalink)
Ex-lurker
i_am_socket's Avatar
Skeeter - '05 Corolla LE
90 day: 35.55 mpg (US)
Mine'll stick to 3rd gear up to ~42 MPH and 2k RPM. Once I push it over into 4th I can keep it there down to ~40 before it shifts down again.
Being able to manually control the shifting would be great, but more for traffic where I'm doing 10 MPH in 1st @ 2,300 RPM and it just isn't enough to get it to 2nd.
Old 12-11-2008, 06:24 PM   #52 (permalink)
Little Blue - '98 Escort ZX2 Cool
Team ZX2
90 day: 46.69 mpg (US)
Big Red - '00 Excursion XLT
90 day: 15.53 mpg (US)
Originally Posted by mhmitszach View Post
Well, mine is about the same. It just takes a lot longer in the cold and I push it to shift because it won't get going any faster otherwise. It'll hold about 43-44 at 2100-2200 rpm unless i give it more gas.
I've been holding it at about 25-26 throttle position and 2500rpm as opposed to in warmer weather 23-24 and 2000 rpm.
I got the car at 106k and I'm at 120k now. As far as I know everything is original on the engine and transmission.
Rebuilt title so who really knows.
You should give me the plans so I can attempt it over xmas break time! =D
How good is your understanding of electronics? Do you understand pulse width modulation? The TCC solenoid requires a PWM signal, I'm still trying to nail down the duty cycle and frequency. I'm not sure how the 1,2,3 shift solenoids are activated yet, strait 12V or PWM. I should know in a few days. Then I can give you some plans if you feel confident enough to undertake it.
Old 12-11-2008, 07:48 PM   #53 (permalink)
Iwishthiswasamanual - '98 Escort ZX2
90 day: 32.95 mpg (US)
Over my head. Haha.
Old 12-13-2008, 10:09 AM   #54 (permalink)
Team ZX2
Don't sweat it, I only understand enough to get myself in trouble. I got the shifting part figured out, the only thing I'm stuck on is the PWM. The one I am looking at is only rated up to 95 degrees F. I'm not sure it will last in this application. I think I'll start a thread and see if an electronic genuises around here can help out...
Old 12-15-2008, 09:34 PM   #55 (permalink)
Team ZX2
Got the HD Lip on tonight, nice a warm out. Much easier to do when above freezing Still it kniked quite a bit and I didn't trim it up real neat. If it works, I'll make a nice one in the spring with some good quality material.
What do you think?
Old 12-15-2008, 10:38 PM   #56 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Steve - '92 Festiva
Looks good, might want to attach some "L" braces to a few places though, so it's flatter, and not turned out on the sides.
If you're having problems with it being/getting kinked, you can always put a few thin wires long-ways across it, with tape, and heat-form it, when you go to make the permanent one.
You make wires that are formed to your bumper, then slowly work the plastic onto them with adhesive, while heating it up so that it's uber-flexible (think: close to melting), then tape it as it cools, then work another 3-4inches down. It will form to those wires, which are already close to the shape of your bumper, which makes it so it won't kink with a little extra bending.
I tell people to pre-form it a bit when using it in their gardens as well, so it won't leave gaps between stones and itself when it tries to straighten out. (it's lawn edging.)
Old 12-15-2008, 11:17 PM   #57 (permalink)
What do you think?
Hm. I might just have to try that.
I want to see some numbers first. haha.
Dunno if you already said, but how did you attach that?
Old 12-16-2008, 12:26 PM   #58 (permalink)
Team ZX2
Well....the commute in to work today left me scratching my head. After putting in the grill block the car seemed to take a noticably less amount of effort to go down the road, butt dyno effort is measured by the sensation of acceleration. This morning it just seemed to take a bit more "pedal" to maintain speed. I really wish I had a scangauge now....
Now let me qualify what I've done. Over the weekend I changed the oil, replaced the 180 degree thermostat with a 195, put on a lighter rear sway bar and put the drivers side front spash gaurds back on for winter, I also found my tires psi had fallen from it's summer, 45psi to 32 psi, so I bumped them up to 45psi again. Mondays commute felt great and it felt very easy to maintain speed. The only change I made last night was the HD lip. I know with all of the changes, I won't be able to get an answer and the volitile temps here will cause fluctuations as well. So I might not have a real answer until spring time or if a scangauge becomes available sooner...We'll see how the next few tanks average out.
I attached the lip exactly as "christ" said above, round part up, fastened thru into the bottom of the bumper.
I was thinking the flare out at the end might force air out past the wheel, vs. slaming into it...???
Old 12-16-2008, 12:36 PM   #59 (permalink)
Team ZX2
As a side note... I filled up the tank last Thursday, did my normal commute Friday, but Friday evening I found my self at a stop light and needing to win I did win, but that one full throttle accel to over 100mph droped me to 30mpg when I topped off the tank Saturday night after all those changes. I'm kinda amazed I still got 30mpg after that sillyness. I by no means condone street racing and this was no where near that.
Old 12-16-2008, 01:29 PM   #60 (permalink)
Steve - '92 Festiva
The flare *might* do that, but it also might create a spoiler effect, inducing drag by trying to produce down-force. Although it might not be that bad, so you can probably just leave it there.
Newb - better MPGs out of a Dodge Neon? stevewww EcoModding Central 7 10-21-2011 08:50 AM
Looking for a fuel efficient solution. I've got a few ideas. CuriousOne EcoModding Central 41 03-28-2009 02:46 PM
Ideas needed for custom license plate.. Chris D. Off-Topic Tech 14 10-21-2008 01:21 AM
jeep aero mod ideas johnpr Aerodynamics 22 08-27-2008 07:45 PM
Porsche 911 engine swap - ideas? beatr911 EcoModding Central 17 05-30-2008 05:37 PM
