Old 02-16-2008, 11:44 PM   #11 (permalink)
ECO-Evolution
Lazarus's Avatar
Days of Yore - '98 E-Bike
90 day: 4979.53 mpg (US)
I'll throw mine in here for some more data if someone wants to figure it out since I'm smart enought. It consistantantly takes 3.7 hours to recharge after a 26 mile ride with assist and a average speed 19 mph.
So if it charges at 46 watts/hour and takes 3.7 hours thats 170.2w
26 miles
.170kw to recharge
6.55 wh/m
No I believe you, just show me a source please
Old 02-17-2008, 03:40 AM   #12 (permalink)
Ryland's Avatar
Tomos Arrow - '05 Arrow ST
90 day: 101.68 mpg (US)
honda cb125 - '74 CB 125 S1
90 day: 79.71 mpg (US)
green wedge - '81 Commuti-Car
I don't have charger numbers, just amp meter and volt meter numbers from the bikes on board meters, cruseing up and down my mostly flate road my very rough amp average is 12, with my voltage droping to 28 volts, my speed is averaged at 22mph with a 27mph top speed (digital bike speedometer) without pedaling and starting from a dead stop.
so I have 12 amps times 28 volts (poorly built 32v pack) is 336 watts while crusing at 22mph comes to... 15 watts per mile, I haven't used it enough to have charging numbers, but my DeWalt batteries that are going on in the spring take 100 watts (Kill-a-watt meter) each to charge a 79.2 watt hour battery pack... yes I know there is some fuzzyness in there, right now my driveway and road are both covered with ice, when that changes I'll get better numbers, but from what I can tell my 22mph crusing speed uses a nice 15 watts out of the battery, ad 20% for charging, then a little more for float and self discharge, and it's I figure 20-22 watts per mile is a safe number... pretty close to Metro's number.
I have a brushless 3 phase motor, so it's a more efficent design then the schwinn, and more powerful to boot, from a dead stop going up a hill without pedaling I've seen the amp meter jump to 28-30 amps or around 1,000 watts.
Old 02-17-2008, 08:54 PM   #13 (permalink)
Blackfly - '98 Metro
90 day: 78.84 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 100.63 mpg (US)
6.55 wh/m
By my calculations, that works out to 5130 mpg (US) equivalent. You're obviously doing a lot of assist!
Latest project: fun weekend project: solar powered electric boat conversion
Old 02-17-2008, 10:29 PM   #14 (permalink)
ECO-Evolution
Lazarus's Avatar
Yes and no i do hypermile the pack. It's just like driving the car. I engauge once I get up to speed, off on descents and hills.
Old 02-22-2008, 10:16 PM   #15 (permalink)
Modding for Eris
Thalass's Avatar
Stockie - '00 Outback GX
90 day: 22.55 mpg (US)
Wife's Car - '06 Corolla
90 day: 30.5 mpg (US)
So what would the formula be to convert kWh/mile into mpg? Or kWh/km into L/100km.
Completely stock '99 Outback!
Electric 4WD on the moon! Win!
Old 02-23-2008, 05:53 PM   #16 (permalink)
Conversions:
1 kWh = 3412 BTU
1 gal (US) gasoline = 114,500 BTU
The bike went 8.7 km (5.41 miles) on 0.12 kWh
0.12 kWh = 409.44 BTU (0.12 * 3412)
409.44 BTU = 0.003576 gal (US) (409.44/114,500)
5.41 mi / 0.003576 gal (US) = 1512.9 mpg (US) equivalent
You can do the mpg/L 100k conversion.
So I guess the formula for mpg (US) equivalent is:
mi. / kWh * 3412 / 114,500
Old 02-23-2008, 06:32 PM   #17 (permalink)
I saw an E-bike that ran off a couple of DeWalt Lion batteries - that was pretty cool too!
Might have been my bike. Built it as soon as I was able to get hold of the batteries at a reasonable price a year and a half ago. As far as I know, it was the first seventy two volt Dewalt setup in the country. That has been long surpassed now and some of my ebike friends are building their own BMS's and chargers for the A123 cells that are used in the Dewalt chargers.
All right. Can't figure out how to load images here. I think I have it as an attachment though.
As for MetroMPG's formula it helps to remember that we can cancel labels when we do the math.
For example: 1 mile/20Whr x 1000Whr/3412 BTU x 114500 BTU/1 Gallon
These are all conversion factors except for the first term which is an actual measurement from one of my own rides. You can see that the Whr terms and the BTU terms will cancel when multiplied out and all that is left is numerical values and miles/gallon. From there it's just a simple matter of punching the numbers into a calculator.
JJ
Old 02-25-2008, 12:08 PM   #18 (permalink)
Thanks for correcting my laziness, JJ. I can still hear my high school physics teacher shouting, "UNITS!!!"
Old 02-25-2008, 08:59 PM   #19 (permalink)
Low Roller - '94 Civic VX
90 day: 52.85 mpg (US)
Wow, I didn't realize they were quite that efficient. I've got to get on that and get one built. Some days when it is sunny, we have extra power from our pv panels, that could be put to use in this manner. For some reason I thought that they would need to be charged w/250 watts for 10 hours or something rediculous.
Old 02-26-2008, 12:43 AM   #20 (permalink)
MP$
Send a message via MSN to diesel_john
Smile
I think you may end up quoting miles per dollar or miles per KW-hr to compare with any energy source because the power plant is burning some fuel at 30 to 40% efficiency by the time it get to the battery. So we might want to stay away from any miles per gallon numbers. Evenually miles per unit of energy from any source will be similiar i suppose but until then miles per dollar is about as fair as you could get. Even windmills and pv panels cost dollars. What do you think about this approach?
How do we add enviromental costs to this?
Engine efficiency improvement through higher temp thermostat? Lazarus General Efficiency Discussion 13 02-05-2008 12:39 PM
Equivalent MPG of cycling - garage feature? MetroMPG Alternative Transportation 21 12-27-2007 02:57 AM
How my home-built bicycle trailer lowers my MPG MetroMPG Alternative Transportation 8 12-14-2007 02:43 PM
Forkenswift equivalent MPG Lazarus Fossil Fuel Free 6 12-14-2007 12:11 AM
First ride on a recumbent bicycle: BikeE MetroMPG Alternative Transportation 5 11-28-2007 09:48 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.2
