Old 03-07-2011, 02:23 AM   #111 (permalink)
There is a difference between charge voltage and reseting voltage of a Lead acid battery. Charge voltage will often be 13.2-13.8 or so... But the voltage will settle down to ~12.6v after an hour off the charger.
Same is true with most battery chemistries... Ni-mh, Ni-Cd, Lifepo4. Lithium cobalt cells, don't really settle down much if at all.
Old 03-07-2011, 02:51 AM   #112 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Originally Posted by Nerys View Post
also remember you are running the car on a single "starter battery" which was never designed for that kind of load.
this is why we would use TWO deep cycle batteries.
Some cars have two batteries. The higher-end version of the Peugeot 607, for example, has a starter battery next to the engine, plus a second batt in the trunk to power all the accessories.
What would happen if a standard starter battery was hooked up in parallel with a deep cycle batt? My guess is that either you would never get the full potential of having a deep cycle, or the starter battery would need replacing pretty quick.
Old 03-07-2011, 03:13 AM   #113 (permalink)
@ Piwoslaw. It's never a good idea to hook up different battery types in parallel or in series. Bad things can happen... Always want to hook up batteries that are as similar as possible (e.g. model, capacity, similar number of cycles etc.)
Old 03-08-2011, 10:08 PM   #114 (permalink)
I don't know how he did it, but obviously it works!
sorry i had to stop reading here for a bit , the mad max moviecar doesnt actually have a working supercharger , it was mounted on a rack bolted over the stock engine and powered with an 12 volt electric motor .
a good supercharger can freewheel so you can still run it without a belt should it break and limp home
as for the alternator : good ideas , i was thinking electric clutch as whell but mounted at the crank end
the gasengine can be used without electricity by mounting a magneto distributor Vertex Magneto for VW Engines by Great Plains Aircraft Supply Co., Inc. there a few more companies making them for racecars mallory is one of them
you could do away with a belt and parasitic drag to the waterpump by mounting an electric waterpump HV Electric Water Pump Small Block Chevy For Sale some models have a bolt on model like this one others have to be made to fit
powersteering ...... we dont need no stinking powersteering again less parasitic drag , there are manufacturers that use electric power assist motors in the steeringcolumb instead of the hydraulic system used in most american cars but popeye arms are cheaper still
so we can do away with practicly the whole fan belt setup (the only exeption being the alternator ) until the battery runs low and that might depent on the time of day since its only needed for the radiator fan interiour fan lights blinkers and startermotor (lights being the biggest draw of power)
i wonder how mush a battery made from A123 M1 Li-Ion cells would run yah , i seen 12 batteries that are powerfull enough to start a car the same way a lead bettery does but its only half the size and weight so you can run 2 with a battery switch and basicly never run without power
Old 03-08-2011, 10:11 PM   #115 (permalink)
@ watahyahknow
Even 4x A123 26650's can start most 4 cylinder gas cars. They are extremely powerful cells and capable of upwards of 120 Amps pulse current.
Some racers replace their car battery with one very powerful small Li-ion battery, just for starting the car. Keeps weight down.
Old 04-11-2011, 09:47 AM   #116 (permalink)
Send a message via MSN to markweatherill
This thread prompts me to ask:
is there any gain in turning the alternator 'off' while cranking? I'm presuming that while the starter is spinning the engine up, it's also spinning the alternator which, because of the big draw on the battery is going to effectively put a brake on the engine...maybe.
Do those of you who run without alternators notice any easier starting?
Or is it the case that an alternator can't do much generating at cranking speeds and therefore doesn't really drag that much while cranking..?
Thanks.
Old 04-11-2011, 10:01 AM   #117 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Good question.
Don't know the answer, but I suspect the alternator isn't energized while starting.
- Either because it's not spinning fast enough, or,
- because the computer tells it not to (as on my Firefly, which doesn't activate the alternator after a starting until engine RPM exceeds ~1900 RPM - ie. until you start driving).
Old 04-11-2011, 10:48 AM   #118 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
My golf a also won't turn on the alt until rpm goes over some 1100 after starting.
Old 04-11-2011, 11:38 AM   #119 (permalink)
I just got home and checked the circuit diagram for the alternator on my Toyota. One of the lines going to it comes from the ECU so it sounds like the manufacturers have this covered.
Old 04-11-2011, 11:45 AM   #120 (permalink)
Grrr :-)
Nerys's Avatar
Cherokee - '88 Jeep Cherokee
90 day: 19.44 mpg (US)
Ryo-Ohki - '94 Geo Metro Xfi
90 day: 50.15 mpg (US)
Vger 2 - '00 Plymouth Grand Voyager SE
Ninja - '89 Geo Tracker
90 day: 30.27 mpg (US)
the problem I see with the A123 cells is how to RECHARGE them with the car. is the alternator output with NO battery buffer stable enough to run a 12v lithium charger? how would that work? what about running the car's stuff etc..
maybe a wee tiny tractor battery to stabilize the system and the A123's to start with?? then again I think the tiny tractor batter WILL start a metro.
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 158 01-12-2013 11:59 AM
How to get instant fuel consumption from Megasquirt TELVM Instrumentation 11 08-29-2011 02:47 PM
Kawasaki starts promoting its bikes' MPG ratings - best = 70 mpg MetroMPG Motorcycles / Scooters 35 09-09-2010 11:41 PM
Truck Trend claims 10% more MPG with K&N in 2009 Ford F-150 after bogus road test MetroMPG EcoModding Central 102 12-16-2009 06:45 PM
mpguino acted up today, lost mpg during fuel cut wagonman76 OpenGauge / MPGuino FE computer 9 06-17-2009 12:25 PM
