Old 03-04-2008, 04:47 PM   #11 (permalink)
Bluebox - '07 Town & Country LX
Last 3: 28.76 mpg (US)
I wonder if a "camper shell on, tailgate and camper shell door open" would have done better?
Old 03-04-2008, 05:43 PM   #12 (permalink)
H4MM3R's Avatar
Plus the camper shell adds wieght. Bad aero+added wieght=
Old 03-05-2008, 08:35 AM   #13 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
The only possible way the open camper shell door could improve the situation is if it was hinged close enough to the roof line, and angled slightly down enough that it would draw the airflow down to reduce the rear wake slightly.
I doubt the open tailgate would have any effect with the cap on - it would be fully involved in low pressure turbulence.
Old 03-05-2008, 12:47 PM   #14 (permalink)
personx's Avatar
My Isusu PU is one of those that has a drag with the tail gate up. I push through a big drag area going from 45 to 50. When I have the bed filled it just flies through that speed. With the tail gate down I don't get that drag spot but it doesn't feel as zoomy as when it's filled. Some day soon I plan doing coast down tests to get some numbers to see just how much differents there is, I'm also planning to make a aero back to test too.
oh also I've not felt this drag driving full size PU's and have not driven other small ones to campare too either. So I can't speak for any thing other that this one, but no hard data to show for now.
Old 01-25-2010, 03:03 AM   #15 (permalink)
Sorry for bump this old thread I am curious how to make GM Manifold Air Pressure Sensor work in 95 Ford F250?
How they get voltage info? Would it able work permanent ?
I am curious how drag on Flatbed and brake before I fix or change them so I want know what mpg or voltage was that after I change..
Old 01-25-2010, 03:36 PM   #16 (permalink)
This cap has big flat surfaces exposed to airflow, because it's bigger than the cab, unlike most modern ones.
Old 01-28-2010, 11:18 AM   #17 (permalink)
Bow
Old School Hashiriya
Bow's Avatar
Fred - '98 Frontier XE
90 day: 26.57 mpg (US)
the GM MAP sensor is just a sensor, you TEE it into an existing vacuum line on the engine
It uses a 5V source, Ground and give an output the varies with the amount of vacuum the engine has.
I have a Suzuki GSX-R 750 MAP sensor on my '91 Nissan 240SX for testing purposed for a project engine I'm building...
Bow
Old 11-17-2011, 01:44 PM   #18 (permalink)
the saturns have one bolted on top of the manifold.super easy to get to. is there a gauge you can hook up to, for readings?
Commercially produced aerodynamic pickup bed cap MetroMPG Aerodynamics 481 04-16-2012 12:31 PM
Easy Aero Fix? (Modding a pickup?) DifferentPointofView Aerodynamics 53 04-13-2012 05:46 PM
SAE report: Pickup Truck tailgate aerodynamics... better up, down, or off? MetroMPG Aerodynamics 5 11-17-2011 02:35 PM
How much do y'all pay for trash pickup? roflwaffle Saving@Home 15 08-23-2009 10:46 AM
