Old 01-19-2009, 01:54 PM   #21 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Zombie Insight - '00 Insight MT
90 day: 62.82 mpg (US)
I used data gathered by MetroMPG on the Blackfly and the 06 Corolla to find the optimum speed to drive each car, based on the premise that saving gas is good, getting to your destination sooner is good, and depending on how much you value your time and your fuel, there is a correct balance. So I assigned a dollar value to time and to gas.
I pay something like $2/gal, but I feel obligated to save gas like it was much more expensive. I value it at $6/gal. Getting there sooner also matters to me, to the tune of about $12/hr.
I plotted the cost per mile for each of MetroMPG's data points, and I had Excel fit a parabola to the result. The optimum speed to drive, considering only time and fuel consumption, is the speed where the cost per mile is the lowest. For me, that would occur around 67mph in the Corolla, and around 62mph in the Blackfly.
However, suppose I was running late for work and I'd be willing to pay $.50 for each minute earlier I arrive, but I still care to conserve gas to the tune of $6/gal. Under these conditions, I'd drive the Blackfly at 68mph, or the Corolla at 78mph.
This is very much back-of-the-napkin. A better optimization problem, like the one that runs in my head whenever I'm behind the wheel, would take in to account that some speeds are not as safe as others (whether too slow or too fast), cars probably wear out faster at higher speeds, and that it's fun to post large MPG numbers. Also, these data only apply to steady-state cruising in economy cars on flat roads with the A/C off, in top gear.
Bottom line: drive faster to save time. Drive slower to save gas. For me, the balance appears to be around 65mph.
Old 01-22-2009, 11:01 AM   #22 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
Originally Posted by RobertSmalls View Post
Where can I get raw data for one of these cars in the high-speed runs?
I don't think the raw data is available. The chart came from here: Green Car Congress: Fuel Consumption at Higher Speeds
Old 01-22-2009, 12:43 PM   #23 (permalink)
I'm new here but is this graph saying at 70kph the vehicle gets 51.x9 MPG? And at 40kph it gets 57.2?
I own an 05 Corolla CE Automatic and it gets nowhere near these figures at those speeds... you stated you borrowed the vehicle so I would assume that means its stock (unmodified). I'm confused how you arrived at these MPG ratings, unless I'm just totally missing something here.
Old 01-22-2009, 12:54 PM   #24 (permalink)
Hi Milkman - yes, the figures posted are correct and the car is unmodified.
But note the test conditions the readings came from, in post #9. FYI, you can't compare real world (round trip, cold start etc.) mileage to these figures. They're simply "constant speed" numbers for a warmed up car under pretty ideal conditions.
Have you done a similar test (level road, cruise control, no traffic etc) and come up with different numbers?
How to get instant fuel consumption from Megasquirt TELVM Instrumentation 11 08-29-2011 03:47 PM
Tested: vortex generators (AirTabs) on a Toyota Corolla MetroMPG Aerodynamics 74 01-05-2011 09:13 PM
Review: 2008 Toyota Avalon Touring Edition (32.8 MPG) RH77 General Efficiency Discussion 2 09-04-2008 02:27 PM
Review: 2009 Toyota Corolla LE (37.9 MPG) RH77 General Efficiency Discussion 22 05-09-2008 05:55 PM
Win an EM Sticker: guess Dad's mileage (Toyota Corolla automatic). Ends Jan 13. MetroMPG Hypermiling / EcoDriver's Ed 51 02-07-2008 10:02 AM
