Old 05-15-2010, 08:49 AM   #1 (permalink)
Testing for an open ciruit in a DC motor
Hi folks,
I really need to ask a dumb question; My pwm-controller (sevcon MOS90) diagonstic led flashes 5 times when selecting drive. According to the manual that could mean an contactor problem or "open circuit motor". I connected + and - from the batteries to the motor and it runs bothways. I presume that there's no open circuit in the motor but I'm not entirely sure...
TIA
Amro
Old 05-15-2010, 11:39 AM   #2 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
...if the problem is not in the DC-motor, then it's either: (1) in the cabling between the controller and motor, or (2) in the controller itself, maybe one of the output device(s).
2011 Chevrolet Cruze LTZ 1.4LT 6A
2009 Pontiac Vibe 1.8L/SFI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
2003 Ford Focus ZX5 2.0L/Zetec 4A
1971 Dodge Charger 318 3A
1970½ Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
Old 05-16-2010, 05:29 AM   #3 (permalink)
I've checked the wiring a couple of thousand times. I 'm going to redo the wiring setup today, i've also checked the contactors. Nothing seems to short circuit them.
I've found a used potbox for this controller and measured it; 5k ohm to zero ohm. Works fine.
My original question is if the motor runs straight on the batteries, it is not short circuiting, right ?
I hope it's not the controller. It would make me very unhappy...
Old 05-16-2010, 08:21 AM   #4 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Zombie Insight - '00 Insight MT
90 day: 62.82 mpg (US)
Correct. Neither a short circuit nor an open circuit.
What if you unhook your controller's +/- output cables and attach them directly to a battery? That ought to test your cables, wiring, and contacts.
Old 05-17-2010, 03:17 PM   #5 (permalink)
Won't that just blow a fuse ? Didn't have time to try it yet. Maybe tommorrow I have a narrow window of oppertunity in my garage. First things first, redo the wiring, fix the controller position and if all fails drive by the electric forklift repair/demolishing guy... Before saturday 14:00
Old 05-20-2010, 02:54 AM   #6 (permalink)
Well found the problem and fixed it. It was really stupid, I was convinced the problem lay somewhere in the control wiring but it turned out one of the cablelugs (?) of the motorground had slipped off. But stayed quite securly in the protective tape I'd used. So, no contact, hence the open circuit indication.
Still got some mechanical problems to solve but I think I can get it finished in time to participate in the Dutch National Motorcarier Championships (NBBK) 2010
Thanks for the advice and I'll post some pic's
Longtime Lurker Looking for Miles ZX40 Electric Micro van mods & information rmay635703 Fossil Fuel Free 46 03-15-2012 07:21 PM
Motor 90V DC PM 19 amp like new rickc For Sale 0 03-26-2010 05:15 PM
GE 48V dc motor heat sensor electrique Fossil Fuel Free 1 08-09-2009 02:10 AM
Revolt Open Source DC Controller Beta Testing jyanof Fossil Fuel Free 18 08-04-2009 11:43 AM
AC Induction Motor used as Brushless DC? WaxyChicken Fossil Fuel Free 5 01-29-2008 09:26 PM
