Old 11-06-2008, 12:11 PM   #11 (permalink)
MechE
The Wagen - '00 Jetta GLS
90 day: 32.72 mpg (US)
Originally Posted by bikin' Ed View Post
Wouldn't infinity be your theoretical max mpg? i.e. going down hill during EOC. Trying to factor in grade, road surface, weight of vehicle (how much fuel, how many passengers, cargo) air speed, wind speed and angle and whatever else I missed, how can hope to get even a formula for max mpg?
Maybe theoretical wasn't an optimal term to use to avoid confusion. Perhaps practical max? The term theoretical is used to find the maximum possible performance of a system (always less than 100%). It's not so much a formula in this case, as much as it is a method to test.
Passengers and cargo wouldn't matter - the maximum possible will be without things you don't carry around all the time. Adding these things will reduce current efficiency further away from the practical/theoretical max.
Challenge me, or correct me, but don't ask me to die quietly.
Old 11-06-2008, 01:32 PM   #12 (permalink)
Moderator
tasdrouille's Avatar
The Guzzler - '08 Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '011 Soul 2U
Originally Posted by trebuchet03 View Post
But, it makes me want to create an FE map -> throttle v. mpg v. speed
You just need an OBDII interpreter ala elm327 and software to do the logging.
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 11-06-2008, 02:09 PM   #13 (permalink)
MechE
I've got two OBD -> ISO IC's in the mail at the moment The 327 is nice, but it's about $30 more :/ Eventually, I'll upgrade to be compatible with everything I think I've got the programming skills to do that though (or, I might just do it manually )
Old 11-06-2008, 02:15 PM   #14 (permalink)
101% win
roflwaffle's Avatar
Camryaro - '92 Camry LE V6
90 day: 31.12 mpg (US)
Toy - '82 Pickup
90 day: 24.44 mpg (US)
Not so much - I want to know FEmax @ Xcondition. Whatever that condition is.
A BSFC map w/ a (reasonable) range of loads corresponding to whatever gear you're in... Like the BSFC map on the bottom of pg. 37, except w/ road load as a swept area w/ high and low bounds, right?
Old 11-06-2008, 03:08 PM   #15 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
90 day: 42.23 mpg (US)
trebuchet03 -
Here's my SGI numbers for my car :
TPS: 0
MPH: ~25
MPG: 62.5
RPM: ~850
Road: Asphalt on the flat
Engine Size: 1.9 liters
Gear: 5th
I have my own custom Elmscan data software, but the MPG algorithm would not "map" properly to what the SG is reporting. Maybe I will do a datalog session for "relative" MPG comparison.
CarloSW2
American Solar Energy Society
Old 11-06-2008, 09:07 PM   #16 (permalink)
Moderator
Well... if you only do top gear and you stay in closed loop, all you really need to log is MAF and RPM. There are quite a lot of ELM327 based interfaces available for less than 30 bucks shipped on ebay. If you want to buy such an interface, I can recommend vendor alpha-bid. He's a bit more expensive than others shipping straight from China, but I bought 2 times from him and I had good service both times.
Old 11-06-2008, 09:34 PM   #17 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
I'm not entirely sure if the Suzuki 1.0L will idle along in top gear without lugging madly. If this helps...
The green line was with the stock transmission, orange/yellow is with the taller final drive. Both are flat road, cruise control, bi-directional averages, and pre-XFi cam (and pre-Kammback). No TPS info though, sorry.
Old 11-06-2008, 11:09 PM   #18 (permalink)
Moderator
I guess we should determine what lugging is exactly. What I read lead me to believe lugging is a condition when you can't gain rpm while at full throttle.
Old 11-06-2008, 11:28 PM   #19 (permalink)
MechE
Doh! I never really considered BSFC.... I guess - as this has morphed a bit... I want to come up with a method to create something similar to BSFC.
So thinking out loud... I think I was hoping for a horizontal asymptote starting off low, going high, then going back low.
I need to put more thought into what it is exactly I'm trying to find....Or maybe... I don't know exactly what to call throttle v mpg v velocity, but I still think it will be somehow useful. Especially if I can make a way to determine it quickly (ie, car shopping )
Old 11-07-2008, 12:18 AM   #20 (permalink)
I don't know the technical definition of lugging; this non-tech definition matches what I thought it was though: engine jerking/shuddering. The kind that makes you go, "oooohhh, that can't be good..."
Treb: sounds like you may be after a metric that I wish government agencies would provide: just show me the fuel consumption across a range of constant speeds in top gear. Forget trying to simulate an entire trip to grandma's house for freaking sake!
EDIT: deleted some other rambling. Need to get some sleep. :P
Theoretical Mileage Charts whatthe EcoModding Central 3 07-06-2008 09:03 PM
Max PSI for Goodyear Eagle rs-a? regor EcoModding Central 2 07-06-2008 05:22 PM
Tires with different max PSI Goldenfrog EcoModding Central 2 06-14-2008 04:42 PM
EcoModding a CRX to the Max: Price? SVOboy EcoModding Central 10 05-13-2008 11:48 AM
