Old 02-16-2009, 06:44 PM   #1 (permalink)
Tracy - '00 corsa
are there any practical things we can do with hot radiator water ?
its easy to divert the coolant hoses in a car -the veg oil diesel guys have taught us that.
what *practical* things can we do with hot water for energy saving?
Peugeot 106 1.5L diesel. Average FE = 70mpg(UK)
Del:mirror/aerial/mudflaps. + grillblock
Old 02-16-2009, 06:46 PM   #2 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
Put it in a thermos and release it again on next start-up.
Old 02-16-2009, 06:49 PM   #3 (permalink)
Tracy - '00 corsa
what about heating up lots of water with a heat exchanger and then using that water for heating your house?
Old 02-16-2009, 06:51 PM   #4 (permalink)
Blue - '93 Tempo
F150 - '94 F150 XLT
You think there is THAT much heated water?
Old 02-16-2009, 06:56 PM   #5 (permalink)
Tracy - '00 corsa
how could that be retro fitted to a car? could we re-route the coolant hoses to a big 10-20litre insulated tank in the trunk or passenger foot-well?
Old 02-16-2009, 06:58 PM   #6 (permalink)
Tracy - '00 corsa
obviously we would need to add more storage for the home heating idea
Old 02-16-2009, 07:01 PM   #7 (permalink)
Blue - '93 Tempo
F150 - '94 F150 XLT
That could be. I don't think 10-20 l will cut it. Imagine a 5 gal pail of boiling water in your house. I don't think there's an appreciable amount of heat there.
I reckon there's calcs to show how much energy is in, say, a 55 gallon drum of coolant at x temperature. Of course, that drum would have 459 lbs of coolant in it...
Old 02-16-2009, 07:07 PM   #8 (permalink)
Tracy - '00 corsa
actually i started this post because i was thinking about the steam engine idea but from a practical DIY perspective.
Old 02-16-2009, 07:14 PM   #9 (permalink)
Tracy - '00 corsa
the thermos flask for hot start up idea would work with a 20litre tank. from my biodiesel days, i know that a 20litre tank should keep its heat over-night if insulated. if its positioned in the passenger footwell the escaping heat would nicely warm the car. but would the weight be an issue?
Old 02-16-2009, 07:31 PM   #10 (permalink)
Tracy - '00 corsa
would it be practical to make a steam engine to replace the alternator using these components?
heat exchanger from ebay -boiler
drill pump from ebay -turbine
drill -alternator
your existing radiator -condenser
a solenoid valve -to do the reciprocating
Subaru Outback Hot Air Intake Results brucey EcoModding Central 22 12-10-2008 07:41 PM
Hot water from oil in the summer time. Xringer Saving@Home 11 09-06-2008 10:02 PM
Good take on things (long) Daox General Efficiency Discussion 8 08-30-2008 04:11 PM
how hot is too hot for metro? SirKeats DIY / How-to 5 08-02-2008 02:27 AM
How hot is too hot for a Metro/Swift Wayneburg General Efficiency Discussion 3 05-07-2008 09:12 PM
