Old 01-06-2010, 12:21 PM   #1 (permalink)
YJ - '89 Wrangler
FOCUS - '00 Focus ZTS
The Wife's Hot Rod - '09 G8 GT
Last 3: 23.22 mpg (US)
Thermostatic block heaters
I recently purchased a car which doesn't really fall into the ecomodder templet. I am going to put a block heater in it mainly to save wear on the engine. It apparently requires a thermostatically controlled heater cord. This will cycle the power on & off according to ambient temperature. I was told that at around 32°f is where it will start to heat the coolant.
I figured the vehicle mfg. was just trying to rape me for a $67 chord as well. I checked on Philips/Temro's website & they say it has to do with the "OBD11" systems. My '97 uses a standard chord & it has the OBDII system.
Does anyone know why they are doing this? I think it's kind of stupid that you can't warm the coolant no matter what the ambient temperature.
Thanks
Don
Old 01-06-2010, 01:20 PM   #2 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
Yeah, sound dumb to me too. Make your own cord?
Lower Grill Block 2005 Honda Civic Arminius EcoModding Central 12 10-04-2011 12:31 AM
Where to buy pad type engine block heaters? extragoode EcoModding Central 31 12-27-2010 04:31 AM
1.5 L Toyota block heater bwilson4web Hybrids 11 12-24-2009 01:30 PM
600w Block Heaters, $15 ea. Help your mileage! Act Now! stevey_frac For Sale 5 05-30-2009 11:53 PM
Spring mounted Grill Block cfg83 EcoModding Central 32 04-19-2009 06:00 PM
