Old 10-05-2011, 05:46 PM   #1 (permalink)
Now on two wheels!
[SOLD] Highway Warrior - '00 Protege LX 1.6L Manual
90 day: 35.93 mpg (US)
Basic Miata - '06 Miata Touring
90 day: 31.65 mpg (US)
Send a message via AIM to 1337
Thinner differential oil for RWD car? ('06 Miata)
I recently sold my '06 Jetta TDI DSG (127k mi) and bought an '06 Miata Touring 5-speed (19k mi). The Jetta's DSG started slipping, and it seemed to be in danger of needing a very expensive replacement transmission. I've wanted a Miata for years, and now I have one!
On the Ecomodder forum, I've seen lots of really interesting experiments and experiences with manual transmission oil. However, I haven't seen as much discussion about thinner differential oil. Has anyone done any experiments with this?
I wonder if something like GM Synchromesh or Volkswagen G52 could be used in my Miata's differential?
I don't drive the Miata hard at all...my favorite thing about the Miata is that it's incredibly fun to drive without driving fast or accelerating hard.
2006 Miata Touring 5MT
2006 VW Jetta TDI 6AT (Sold to buy Miata)
2000 Mazda Protege 1.6L 5MT
2002 Mercedes C230 Coupe 5AT (Water damage, totaled)
Old 10-05-2011, 05:56 PM   #2 (permalink)
V8 guy
Sub - '84 Suburban C10
Pickups
camaro - '85 Camaro Z28
Both my vehicles are rear wheel drive and the thinnest I would try is a synthetic 70w80 or 70w85.
Gear Lube - Oils, Fluids & Additives - Oils, Fluids & Sealer - SummitRacing.com
There is even a 75w60 weight, kind of different. Too bad it only come in 5 gallon buckets at a cost of $220.
1984 chevy suburban, custom made 6.5L high compression diesel.
New engine is in and should be good for 29mpg highway.
1985 chevy camaro mostly stock.
1337 (10-16-2011)
Old 10-05-2011, 06:14 PM   #3 (permalink)
Now on two wheels!
Good idea! Is this an example of what you have in mind? Red Line Synthetic Oil - Gear Oil for Manual Transmissions - MTL 70W80 GL-4 Gear Oil According to the Red Line specs, this oil has 10.6 cSt viscosity at 100 degrees C.
Old 10-05-2011, 06:27 PM   #4 (permalink)
V8 guy
Pickups
I would be much more comfortable using a 70w80 weight MT oil in a diff compared to something possibly way too thin like ATF or GM synchro oil.
If I ever decide to swap out my GM 10 bolt rear in my camaro for something else I will be sure to fill it with ATF and drive it for a while just to see what happens.
Old 10-05-2011, 06:45 PM   #5 (permalink)
I believe that the 65+ mods list does mention thinner diff oil as a possible way to reduce driveline losses. How thin you can go is definitely a very good question, one I don't know anything at all about. I've only ever owned cars with transaxles, where the transmission and diff share a single oil supply.
-soD
Old 10-05-2011, 07:20 PM   #6 (permalink)
Regency - '94 S10 LS
90 day: 29.2 mpg (US)
yea i had the same question because im about to change mine and its never been changed so ive been told... (220,000 miles) I cant see it never being changed but i guess i will see when i actually change it. I just need to figure out what im going to change it to..
Think im just going to go with the 75w-90 synthetic
The Following User Says Thank You to regency For This Useful Post:
1337 (10-16-2011)
Old 10-05-2011, 08:21 PM   #7 (permalink)
JRMichler's Avatar
Nameless - '06 Canyon
90 day: 33.19 mpg (US)
I used to own a 1968 Volvo 144. I changed the differential oil in it to 75W90 synthetic. I don't know what I drained out, but it was definitely thicker than the 75W90 I put in.
Then the car developed a loud gear rattle at part throttle at 65-70 MPH, my normal long trip speed at the time. I believe that that rear end needed a slightly thicker oil. Any mileage improvement was very minimal, well under one MPG.
Hypoid gears need a minimum oil viscosity to prevent metal to metal contact.
The Following User Says Thank You to JRMichler For This Useful Post:
1337 (10-16-2011)
Old 10-05-2011, 08:34 PM   #8 (permalink)
Depends on the gears really, and how the were setup, also how much backlash they have at time of oil change.
If mines starts to make noise i will go back to 80w-90 and consider it a flush of the old fluid
Old 10-08-2011, 01:47 PM   #9 (permalink)
6 speed Diesel FTW!
The Golf - '02 Golf GLS TDI
Diesel
90 day: 63.94 mpg (US)
Mongoose - '05 E-bike AWD
90 day: 1810.34 mpg (US)
Send a message via AIM to dremd
Redline ger oil has an actual viscosity in the 50-60 range when hot. Works great even in high horsepower applications.
Check out bobistheoilguy forums for way better information than I can provide.
6 speed ALH TDI
The Following User Says Thank You to dremd For This Useful Post:
1337 (10-16-2011)
Old 10-09-2011, 11:24 PM   #10 (permalink)
Recycling Nazi
Bror Jace's Avatar
Blue Bullet - '06 Civic Sedan LX
90 day: 35.68 mpg (US)
Arrow
One problem you are going to have is not so much the viscosity as it is the additive package. For a diff, you'll want a GL5 add-pack.
Syncromesh, Red Line MTL, Amsoil MTF and the like are GL4. I don't believe any of those are dual rated GL4/5 ... but some 75W-90s and 80W-90s are.
For really thin rear-end gear oil, I might try this stuff:
Red Line Synthetic Oil - Gear Oil for Differentials - 75W85 GL-5 Gear Oil
or:
Red Line Synthetic Oil - ShockProof® Gear Oils - Lightweight ShockProof®
The Superlight Shockproof is likely too thin for proper durability.
I think with a Miata, though, you're #1 enemy is wind resistance. I love my convertible, but it's an affront to the aero gods.
--- Bror Jace
The Following User Says Thank You to Bror Jace For This Useful Post:
1337 (10-16-2011)
