Old 05-27-2017, 02:50 AM   #31 (permalink)
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
90 day: 56.86 mpg (US)
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
Originally Posted by 14'ecocruze View Post
So you recommend a 0w30 then vs dropping to 0w20? So even running such light load on engine you still suggest refraining from dropping to lower viscosity at temp oil yet. I assume your basing this primarily on the fact it's a turbo engine? Guessing you would also suggest no EOC as well?
No, as long as you don't go from boost to directly turning off the engine it should be fine.
But you wanting to EOC definitely reinforces my argument that you shouldn't drop hot oil viscosity. You will cook the oil in that turbo and could potentially kill it prematurely.
Also, drop the attitude, I was just trying to help. If you wanna blow up a 3 year old car trying to save literally pennies per fill up (if even that) because you want to run thinner oil on a turbo engine, go right on ahead.
The Following User Says Thank You to Baltothewolf For This Useful Post:
101Volts (03-05-2018)
Old 05-27-2017, 05:50 AM   #32 (permalink)
CruzeMTgrind
BlueBawls - '14 Chevrolet Cruze Eco
90 day: 45.75 mpg (US)
Eddie - '02 Ford Explorer Eddie Bauer
90 day: 26.32 mpg (US)
Sorry if I seemed to have any attitude. Little to objective in seeing where your view was based. My apologies and thank you for the input.
Old 05-27-2017, 09:00 AM   #33 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
Mobil used to make plain zero weight synthetic
How did that compare?
Old 05-27-2017, 03:15 PM   #34 (permalink)
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
Last 3: 24.65 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 24 AUTO
Pickups
90 day: 22.62 mpg (US)
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
If? You decide to EOC a turbo anything install a pyrometer and dont shut off toe coolent (oil) till it cools to 300f for conventional oil and 4-500f varying by brand of synthetic.
Another consideration is, if it is flat towable (aka lube is flowing with the engine off)
Coking and abuse are the normal turbo failure causes. Coking is the deposits caused by the lighter compounds evaporating leaving the heavies to become solids blocking the flow of coolent (oil).
Gumby Stay Flexible.
1st gen cummins 91.5 dodge d250 ,16cm turbo housing ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 29.3mpg 97mi 3.311usg 7/27/16
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
Old 05-27-2017, 04:47 PM   #35 (permalink)
V8 guy
A gas motors EGT just about will never get below 500F.
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
