Old 07-24-2008, 11:12 PM   #21 (permalink)
Send a message via AIM to pumafeet10
i googled this a few times and also found some info on wiki, i know some don't trust but there have been others that have used a six stroke design but instead of injecting water for the last two strokes then just injected compressed air i got almost the same effect. any thoughts on that being a lot less complicated then water since there are alot of other systems that are needed to work with the water system.
Old 07-25-2008, 02:22 PM   #22 (permalink)
2k2Prot5 - '02 Mazda Protege5
90 day: 33.82 mpg (US)
BDC... ever heard of a steam engine? make something hot and when water hits it, it will turn to steam and evaporate and expand. I think that stuff's been around for a while... even longer than the duece coupe, for that matter. And its has proven reliable...
Nobody is trying to get something for nothing here. Pumping heat out your rad is just getting nothing for something! Take that heat, make it into steam, use that steam to keep pushing the car. Its not magic.
Old 07-25-2008, 02:28 PM   #23 (permalink)
Some people break down the H2 and the O and burn it. But not cost effectively. Ignore all discussions and modifications that involve this.
Water can be useful for piston/valve cooling and in some cases, good for turning some of this heat into pressure. But ecomodders are all running their engines at low outputs anyway - so excess heat isn't such a problem.
Old 07-25-2008, 02:30 PM   #24 (permalink)
excess heat is ALWAYS a problem. Any time your thermostat opens, you are just using hard-earned gas money to heat up your engine bay. Any way that you can use that heat to push your car forward is good!
Old 07-25-2008, 03:46 PM   #25 (permalink)
Ecoformance Engineer
Vince-HX's Avatar
EJ7 - '96 honda civic Hx
Last 3: 58.02 mpg (US)
water is good
add a little meth and its even better
70 mpg or die modding
www.full-race.com
looking forward to seeing what kind of uber-sipper slinks out of the full race skunkworks.
Old 07-25-2008, 03:50 PM   #26 (permalink)
Ok, as the piston moves down on the power stroke and cylinder pressure decreases, direct inject some water to flash into steam and add some more pressure.
I'm not smart enough to tell you if the expanding steam pressure is enough to offset the cooling/contraction of the existing combustion gases.
Old 07-25-2008, 04:08 PM   #27 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 40.02 mpg (US)
90 day: 49.62 mpg (US)
I had an idea for a two-stroke engine that was two-strokes IC, then two strokes steam. It was inspired by the Crower process, but the idea was to use a half-speed cam like a four-stroke, which would operate two sets of valves, first set for the combustion process, the second set to exhaust steam after the steam expansion cycle.
Another idea is to have the conrod rigidly attached to the cylinder and project through a solid bottom in the cylinder, and the top be IC and the bottom is steam. That may be difficult to lube though - how did they do it with the old steam engines?
Old 07-28-2008, 08:35 AM   #28 (permalink)
Originally Posted by BlackDeuceCoupe View Post
Why?
Because it can take heat energy and transform it to kinetic energy without anything more than a change of state. Once it leaves your exhaust, it cools and condenses on the nearest pretty little flower to keep the hippie's garden growing.
BDC, you seem like a reasonably intellegent dude and you yourself proclaimed your ultimate status as researcher king of the world in a different thread. Go read up on it and you'll understand why this engine isn't totally bogus. It may not yet have been engineered to perfection, but the idea is quite sound and aluminum-hat-free.
Good point about the 2-stroke. I wonder if a TBI 2-stroke could simply choose when to spray water or gas based on cyl wall temps. Engine is too cold, run as normal. Reach operating temp and do 1 water cyclefor every 9 gas cycles, then, 2/8, then 3/7 till a temperature equalibrium is met... interesting.
Old 08-15-2008, 05:08 PM   #29 (permalink)
Originally Posted by elhigh View Post
{snip}
I think this idea is even more practical than the original 6 cycle setup. The bottom steam engine cylinder could be engineered as a regular steam engine with the exception that it would generate its own steam when water was injected. The two cylinders would be constructed so that the heat from IC engine could be used by steam cylinder.
A temperature monitor would determine when the water would be utilized, the rest of the time it would just idle.
My first post, nice forum!
Rolf
Old 08-15-2008, 06:01 PM   #30 (permalink)
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
I'm not holding my breath. No progress after two decades...he's hit a rock.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
6 stroke engine idea? fredd7924 EcoModding Central 24 04-27-2010 08:00 PM
Thoughts on my grill block? gascort Aerodynamics 4 07-03-2008 02:23 PM
Thoughts for bumper stickers- regor EcoModding Central 6 06-27-2008 10:11 PM
Opportunity Parking - Thoughts? SVOboy Hypermiling / EcoDriver's Ed 21 01-12-2008 12:24 AM
