Old 05-29-2008, 12:28 PM   #11 (permalink)
FastPlastic's Avatar
98 Cherokee - '98 Cherokee
90 day: 15.66 mpg (US)
ZX7R Ninja - '99 ZX7R Ninja
90 day: 42.45 mpg (US)
I've pondered this myself. My jeep tends to be kinda jumpy at the low end. What if you just put something in the groove the throttle cable sits in (Strip of metal, plastic, etc). The bigger that cam gets the farther you have to push the petal right? If you put the strip all the way around you would loose a little top end. so what about just 2/3's? Making the cam more of an oval shape. that way when you hit the top end the sensitivity would go up. Just judging by the size of the cam I don't think it would take much to notice the difference.
Adjusted for my driving habits. 80%city/20%Highway.
20mpg city/30mpg highway or bust! Check out my mods so far
Old 05-29-2008, 01:45 PM   #12 (permalink)
A lot of vehicles are calibrated to act this way.
50% power with 30% throttle.
Makes them feel "faster" and "more responsive" than if they had a linear progression.
This philosophy will probably not change in the future as the power/weight ratio decreases.
As to fastplastic comment, I find my 97 Jeep Cherokee to be more linear than other cars. I always assumed they wanted good throttle modulation at the low end for "rock crawling" type stuff.
Old 05-29-2008, 01:52 PM   #13 (permalink)
Red Egg - '95 Aspire
90 day: 38.51 mpg (US)
Dodge SRT-4 - '04 Neon SRT-4 2.4L Turbo
90 day: 26.24 mpg (US)
I would first play with spring tension. go to a junkyard and swipe 2 extra springs. See if you can wind and/or cut one tighter, and make the other one looser and see how it goes. while its apart or better off the car blast that thing off inside and out with carb cleaner. Gotta eliminate all variables here. Next would be to modify the geometry as the guy above said, ovalling out the cam the throttle cable rides inside. by doing this you are effectivly making the cable longer which the slack needs to be taken up somewhere.
Is this something that has always been a nuisance or only when trying to "featherfoot?" Your cable could be worn but usually they wear the other way around, where you have to press more to get the car to open up, then all of a sudden it does, which is double trouble for your mpg's. Extra response off idle is what happens when a TB is too large. I'd hate to suggest corking up the pipe right before the tb entrance because you could lose regular performance.
Old 05-29-2008, 04:55 PM   #14 (permalink)
Renaissance Man
Formula413's Avatar
Sleepwalker - '97 Firebird Formula
90 day: 20.04 mpg (US)
Spock - '92 VN750 Vulcan
90 day: 49.39 mpg (US)
03MX - '03 Civic Hybrid
90 day: 49.04 mpg (US)
The car has always been jumpy at light throttle. I like the idea of modifying the cam on the TB, although i think if I could eliminate the feeling of stickiness right off idle I would achieve the desired result.
More choices...
Aerocivic - how to drop your Cd from 0.31 to 0.17 basjoos Aerodynamics 558 04-29-2012 10:18 PM
Cold air VS Warm Air Intakes - what's the difference? deadman1474 EcoModding Central 49 03-25-2012 10:47 PM
Honda IACV explained TomO Off-Topic Tech 10 11-25-2011 12:59 PM
What's better on hills: DWL or Pulse up, Glide down? monroe74 Hypermiling / EcoDriver's Ed 81 05-17-2008 10:36 AM
Motorcycle TPS (Throttle Position Sensor) dcb Instrumentation 3 04-28-2008 07:24 PM
