Go Back   EcoModder Forum > AltModding > Saving@Home
Old 06-12-2008, 02:37 PM   #51 (permalink)
6 speed Diesel FTW!
The Golf - '02 Golf GLS TDI
Diesel
90 day: 63.94 mpg (US)
Mongoose - '05 E-bike AWD
90 day: 1810.34 mpg (US)
Send a message via AIM to dremd
Originally Posted by elhigh View Post
Plumb the dump loop to your biodiesel processor. Why pay for heat when you have a convenient fusion reactor beaming power directly to your house?
In the works. there is no hot water plumbing anyplace near where the bio processor will live. I'm definitely planning on using it at lest for drying. I will however need a circulation pump, any ideas?
Damn I've got to build one of these things. And the place I want the water heater is under the house. Sure, it'd put it outside of the insulated envelope, but where I live winters aren't that bad, and even if I wound up dumping some amps into it once in a while, it'd still be way ahead of dumping amps into it all the time. It'd also take it out of the air conditioned space, and that's more important to me.
There is very little heat coming off of the tankless heater; it is in my old insulated water heater cabinet, and it isn't warmer than outside of it (was blistering with propane.
IMHO not worth moving . . . .
6 speed ALH TDI
Old 06-12-2008, 05:53 PM   #52 (permalink)
ttoyoda's Avatar
I have been running all PVC for a while now, so nothing I can do about past lead exposure. All I can say is that we never drink the water here, other than Ice which is on the cold side anyways.
I think it is only a big issue (well, depending on HOW much lead) for little kids.
Older kids are killing brain cells with booze etc. anyway, so really, who cares about lead.
Old 06-16-2008, 08:30 PM   #53 (permalink)
Blue - '-1823 P/U
Originally Posted by dremd View Post
If you want I can take some exact measurements/ better pics of mine so you can build your own. I wouldn't bother "buying" one like this, they are to easy to build.
yes,, please
Old 08-30-2008, 09:28 PM   #54 (permalink)
6 speed Diesel FTW!
Diesel
Just boarded up the glass of the Solar heater. I also lowered my elevation all the way flush with the roof top. It is bolted down with 8 3/8" 5" lag bolts through a 2x12 and in to a 5x9 beam on one side. On the elevation side it is held by 2 1/2" all thread rods with washers on the heater side.
I'm not terribly worried about it; I'm more worried about the 4 Dishes (1Starband + Dish network; 1 dish 500; 1 dish hd; and WildBlue) up on my roof.
6 speed ALH TDI
Old 09-09-2008, 08:57 PM   #55 (permalink)
6 speed Diesel FTW!
Diesel
Made it through ~ 100 mph winds no problem what so ever.
Wild Blue Dish didn't fair so well. . . . . Back up now.
6 speed ALH TDI
Old 09-10-2008, 07:57 PM   #56 (permalink)
I'd rather be biking
boxchain's Avatar
Beater Hauler - '92 Pickup
Lexie - '98 Civic LX
90 day: 39.46 mpg (US)
Rentaclipse - '08 Eclipse ?
90 day: 28.28 mpg (US)
Glad to hear Gustav wasn't too bad to you...my neighbors were nice enough to send over my roof vent :O
My bike runs on dihydrogen monoxide.
I like to use these acronyms
Old 09-10-2008, 09:37 PM   #57 (permalink)
Subaru GL - '86 GL Hatchback 4X4
90 day: 25.36 mpg (US)
so let me get this straight dremd...water goes through the solar heater and into the bosch unit...but because its already heated your bosch just maintains a steady temp...thus using less propane because it knows the waters already heated? correct?
Old 09-10-2008, 09:55 PM   #58 (permalink)
6 speed Diesel FTW!
Diesel
For the third hurricane in a row we have been incredibly fortunate.
This one was looking bad, but it wasn't bad at all at my house, my camp 20 miles away got hit fairly bad. If anyone is incredibly interested; check out MobileMe Gallery
6 speed ALH TDI
Old 09-10-2008, 09:58 PM   #59 (permalink)
6 speed Diesel FTW!
Diesel
98% correct; the only difference is I have switched from propane over to Electric.
Some days the bosch doesn't even switch on, somedays it does some work, and sometimes it is darn near the only source of heat.
6 speed ALH TDI
Old 09-10-2008, 10:07 PM   #60 (permalink)
wow...definatly a system worth considering
Mini experiments: 300w vs. 800w block heater warm up time MetroMPG EcoModding Central 40 01-06-2011 02:33 AM
