Old 08-24-2011, 02:09 AM   #1 (permalink)
Enki's Avatar
Time for some overkill.
Because I will eventually run my car at the ragged edge, I aim to make damn sure I know what's going on with it.
So, with a couple of goals in mind, I did some research and wound up buying a Nook Color, and dropping a custom ROM (OS) on it. Combined with the Torque app, I have some pretty decent monitoring going on.
First, the PLX Kiwi Bluetooth:
Next, how it's wired/routed:
Sunny Nook:
Shaded Nook:
RAM mount:
Torque UI:
So, it works, but I'm running into issues with the speed of updating which is looking to be a problem with the adapter (as I've tested everything else). I guess all that remains is to get on the horn with PLX and find out some info about this device, as I really need the high speed resolution in logging.
Old 08-24-2011, 10:25 AM   #2 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
...interesting, so you're "blue-tooth" transmitting the OBD-II signals up to a Nook Color and using what software display package?
2011 Chevrolet Cruze LTZ 1.4LT 6A
2009 Pontiac Vibe 1.8L/SFI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
2003 Ford Focus ZX5 2.0L/Zetec 4A
1971 Dodge Charger 318 3A
1970½ Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
Old 08-24-2011, 10:50 AM   #3 (permalink)
Spaulding Rally Master
Fat Charlie's Avatar
Spaulding Bobsled - '05 Legacy GT
Subaru
90 day: 30.71 mpg (US)
That's a good size for a Torque display. Very nice job.
At last fill-up, number 30 by POE (active)
47) "Drive without brakes" (DWB) Minimize use of the brake pedal. Each time you press it, you're effectively converting gasoline into brake dust and heat.
Old 08-24-2011, 12:03 PM   #4 (permalink)
Enki's Avatar
The Android app is called Torque. There is a free version, but I'm rolling with the paid version.
More info on the Nook Color:
Fully rooted and flashed
Running CyanogenMod 7 (latest nightly alpha build)
Overclocked from 800 Mhz to 1100 (with room to grow)
16 gig class 10 SD card
And yes, I can still read books on it.
Like I said before, there is a problem with my setup; the data rates aren't exactly stellar. According to PLX's support forums, their dongle runs at full bluetooth 2.0 speed, so that shouldn't be the issue; I'll be doing one more test this afternoon to figure out if it's the bluetooth radio on the Nook or something else.
It's decent, but not yet perfect.
Old 08-25-2011, 07:34 PM   #5 (permalink)
Black Knight - '94 Corolla
90 day: 61.92 mpg (US)
I got a nook color and want to root it bad but have not found a good step by step on how to do it. I dont care to OC though.
Old 08-25-2011, 08:36 PM   #6 (permalink)
Enki's Avatar
It is a little tricky, but basically you need a MicroSDHC reader (or a cell phone will do) and a few files to put on it. Essentially, the Nook will boot from the SDHC card natively, so you don't technically have to root it I don't think.
XDADevelopers has a whole section on the Nook color; you should start there and read up.
Old 08-25-2011, 08:53 PM   #7 (permalink)
JasonG's Avatar
1 Ton - '94 C3500
90 day: 19.7 mpg (US)
Big White Brick - '03 Express Van
90 day: 15.19 mpg (US)
I am using a "cheap ebay" ELM327 unit.
No data stream issues.
Torque is running on a Tmobile MyTouch Slide.
I hope its not the nooks bluetooth transmitter as I hope to do the same when I have a few loose $$
Support Bennelson !
I can't understand why my MPG's are so low..........
16000lb, 41' Toy Haulers are rough on FE!
Old 08-25-2011, 09:09 PM   #8 (permalink)
Enki's Avatar
I did a mountain of testing; long story short, it isn't the Bluetooth kit in the Nook Color. If anything, the hardware it has is actually overkill on a fairly significant degree for what Torque needs.
Ian (the Torque developer) has some improvements in store for CANBus interaction which should significantly improve polling/logging rates, so time will tell.
For those of you that care, on the latest nightly I was able to transfer a file from Windows to the Nook via Bluetooth at just over 100 KBps; My HTC Evo running the same nightly (different kernel, obviously) clocked only a few KB faster.
Basically, I'll just let Torque auto-update and one day it will grow a mohawk and start headbanging data out.
Old 08-25-2011, 10:13 PM   #9 (permalink)
Subaru
Ian does a good job. It's a great app.
