Old 05-25-2008, 12:49 PM   #21 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
But there's diminishing returns for anything related to fuel economy, that's not a new idea, nor do I think it's important to the question of safety.
Old 05-25-2008, 01:19 PM   #22 (permalink)
Legend in my own mind
trikkonceptz's Avatar
Evil Pumpkin - '08 xD RS 1.0 #1633
90 day: 35.45 mpg (US)
Silent Silver Killer - '010 Insight EX
90 day: 51.5 mpg (US)
Wouldn't the optimal efficiency of a tire be contact patch size equals tire size?
Meaning if your vehicle has 185 / 60 / 15 then the patch size should be 185mm. I heard a way to measure this using a simple string around the bottom of the tire and some formulas. I'll dig it up and post it to see if we can prove it true.
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
Old 05-25-2008, 01:34 PM   #23 (permalink)
Pushrod - '02 Cavalier
It is important to safety because as you start to overinflate, MPG gains level off and your safety starts to fall off rapidly to the point where you're giving up a lot of safety to secure a very small amount of economy.
Some of the guys on the Cavalier forums think I'm insane for running my 44psi max tires, at 44psi. Granted, they might be on the other extreme, but do you really want to find out how thick the margin of safety is on your tires? Remember that this margin accounts for manufacturing variances that can't easily be quantified. Just because so and so was fine running at 25% over, you might not be so lucky.
Old 05-25-2008, 02:00 PM   #24 (permalink)
is awesome
At what psi? Sources/data?
KU School of Engineering
'72 Datsun 240z
'96 Chevy lumina
Old 05-25-2008, 02:20 PM   #25 (permalink)
I came across this link: http://www.performancesimulations.co...on-tires-1.htm
It doesn't really answer our questions, but the data collected by the tire manufacturer does illustrate the varying contact patch size in relation to load and PSI.
Old 05-25-2008, 02:47 PM   #26 (permalink)
6 speed Diesel FTW!
The Golf - '02 Golf GLS TDI
Diesel
90 day: 63.94 mpg (US)
Mongoose - '05 E-bike AWD
90 day: 1810.34 mpg (US)
Send a message via AIM to dremd
Originally Posted by CapriRacer View Post
I've been reading about folks inflating tires over the maximum printed on the sidewall and this is one site where this has been reported. I've joined just to add technical background as to why that is a bad idea!
Sweet!
Could you please provide some technical background as to why it is a bad idea?
6 speed ALH TDI
Old 05-25-2008, 03:24 PM   #27 (permalink)
larryn2o's Avatar
i run 175/50r13 tires , recommended max inflation is 51 PSI . not sure if they qualify as low rolling resistance , but i like the way they look.
Old 05-25-2008, 03:39 PM   #28 (permalink)
I think we were just taken for a ride folks .. funny how our "tire Engineer" hasn't been back on since the post and really didn't give us any information with his first post.
I think he wanted to spark some argument and was dissapointed when we began a rational conversation ...
Old 05-25-2008, 05:27 PM   #29 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Christine - '98 Metro Base
90 day: 62.59 mpg (US)
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
^ I agree!
Old 05-25-2008, 05:34 PM   #30 (permalink)
It's too bad really. Tires seem to be pretty complex... they aren't just balloons. I don't think we'd ever settle these arguments without some more understanding of what exactly is going on. Even simple ideas like choosing the lowest rolling resistance tires seem to be complicated by the tire size and pressure.
Proposed braking test: comparing tire pressure @ 50 psi vs 35 brucepick EcoModding Central 55 06-11-2011 09:29 PM
Tire pressure (of winter tires) tasdrouille General Efficiency Discussion 20 08-12-2009 02:38 AM
New tires, advise? Chris D. EcoModding Central 35 06-09-2008 10:53 AM
Article: Green push hits tire makers MetroMPG General Efficiency Discussion 0 12-16-2007 08:14 PM
