Tire Engineer here - concerned about hyperinflating tires
I've been reading about folks inflating tires over the maximum printed on the sidewall and this is one site where this has been reported. I've joined just to add technical background as to why that is a bad idea!
Welcome ... and OK, where is this information, you kinda left us hanging ...
welcome to ecomodder...i dont personally inflate past the max, but i know many who do...what technical issues do you speak of?
Welcome to the site. As the others have mentioned I'd definitly like to see some testing that you have done to prove this is a bad idea. We have many people running max sidewall pressures here without any problems, perfect tire wear, and greatly increased tire life.
...Ya lost me :confused: Folks have to back up claims here. We crave data. RH77 |
My tires were 11psi over inflated. They're mud tires too. I took corners fast and did hard braking to test failure. No problems, but I reduced pressure by 5psi to be on the safe side. (the tires are at least 5 yrs old too, but taken care of).
Chris |
Perhaps we should discuss how poor the gages are on the car tire pumps. They can be off by over 10 psi in my experiences.. They always warn bicyclists not to use them for that reason. Also, they heat up a lot so you increase pressure at highway speeds if you inflate cold. I would say the concern isn't going beyond the limit of the sidewall by a few psi, but in how you do it and using what equipment, If you have other data, please enlighten us.
Frank, I think quite a lot of threads here and on other FE forums have got to the bottom of this as far as RR is concerned. What do you believe has been left uncoverred?
The only concern I still have is related to some areas of the safety factor, as I haven't seen much data appart from annecdotal evidence. |
http://www.officer.com/article/artic...on=19&id=27281
This shows the relationship between temperature and tire pressure. Their test indicates that for a 20 minute drive you can expect ~+4Psi. http://www.tirerack.com/tires/tirete...e.jsp?techid=1 Quote:
-Notice, no mention of higher than normal wear, or blowouts. |
