Old 08-12-2009, 02:38 AM   #21 (permalink)
fidalgoman's Avatar
The Michelin Ice X tires on my wifes 93 Topaz have a max rating of 51 PSI. So when the weather was good all summer I ran them at fifty (from the previous 32). It made almost 2 mpg without any appreciable wear abnormalities. The ride is harsher but the wear and mileage are great.
Note, I have experimented in snow, ice and rainy weather and from experience hard tires make great sled runners in the white stuff. So whenever the weather is bad a lower softer more compliant tire makes a world of difference. By the way I drive about ten K miles per year in the snow alone in my work. About thirty K total on my work car so mileage is important.
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 140 11-21-2011 10:13 AM
Proposed braking test: comparing tire pressure @ 50 psi vs 35 brucepick EcoModding Central 55 06-11-2011 09:29 PM
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 68 02-21-2010 09:45 PM
Relative tire pressure? bwilson4web EcoModding Central 4 03-16-2009 11:35 PM
Tire pressure sabotage Piwoslaw EcoModding Central 16 12-16-2008 02:37 PM
