Old 05-24-2013, 02:55 PM   #1 (permalink)
ecowannabe
Skeeter - '89 Ford Escort LX
Tire sidewall and mpg
Hello all, looking to increase the tire size on my sidekick just a little bit (a little over an inch) from stock as I have heard good reviews from performance and mpg but I have a question...
Which would effect mpg more? The sidewall height or the width of the tire? I (obviously) have to pick one or the other to increase to gain the extra inch I am looking for
Thanks for any input!
Josh
Old 05-25-2013, 07:00 AM   #2 (permalink)
Tire Geek
CapriRacer's Avatar
Josh
First, changing tire size has a small affect on fuel economy, where careful selection of the tire itself can have a larger affect.
But if you strictly want to look at size:
Barry's Tire Tech
About half way down the page, I list a formula derived from the data - and the short version is that width is ever so slightly better than aspect ratio based on single increments. Please note that a single step up in size doesn't get you a whole inch in diameter.
- BUT -
You may have things that restrict what changes you can make in tire size:
1) Width of the rim.
2) Available aspect ratios
You only told us you have a Suzuki Sidekick, but didn't tell us the model year, and the type (2WD, 4WD) nor the tire size you are starting out with. I did a little research and it turns out that there were a variety of tire sizes mounted to Sidekicks - and while the rim widths are wide enough to go up a size or 2, many of the original sizes are maxed out on aspect ratio (75) and you won't find anything with a higher aspect ratio.
But you weren't considering going larger in rim diameter, were you? That would yield even more improvement over both a single increment in either width or aspect ratio - and then again a single increment is not an inch larger in diameter - and, again, the change is small compared to what differences there are in the tires themselves.
CapriRacer
Visit my website: www.BarrysTireTech.com
New Content every month!
Old 05-25-2013, 09:19 AM   #3 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
first try searching.....
there are MANY threads on this topic.
I have done this on both my cars with success.
Q45 245/45/18 to 245/50/18
sportage 235/60/16 to 235/70/16
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 05-25-2013, 09:22 AM   #4 (permalink)
mcrews's Avatar
http://ecomodder.com/forum/showthrea...ins-24006.html
http://ecomodder.com/forum/showthrea...res-25725.html
a couple for starters.....
ECO MODS PERFORMED:
First: ScangaugeII
Old 05-26-2013, 09:26 PM   #5 (permalink)
'Good reviews' = it's a cheap way to alter the rear axle ratio—makes it more of a 'freeway flyer'.
I look forward to my first set of these, the Bridgestone “Large & Narrow Concept Tire”:
<26" diameter on a 19" rim.
Old 05-26-2013, 09:54 PM   #6 (permalink)
ecowannabe
I have a 1998 Suzuki Sidekick 2WD, the stock tire size was 215/65/r16, I think I am gonna go with the 225/70/r16
The Following User Says Thank You to jmedia For This Useful Post:
mcrews (05-26-2013)
Old 05-26-2013, 10:21 PM   #7 (permalink)
mcrews's Avatar
check your clearance all around!
ECO MODS PERFORMED:
First: ScangaugeII
