Old 08-08-2008, 07:20 AM   #1 (permalink)
Big Blue - '06 Dakota Quad SLT
90 day: 20.36 mpg (US)
Miazda - '96 Miata mx-5
90 day: 44.14 mpg (US)
Tire size
We all know that taller tires give you a taller gear, but make you less aero. And shorter tires lower the vehicle making it more aero, and take less energy to get them up to speed (weight etc being equal). Would it then make the most sense to use shorter tires on a vehicle used mostly in city driving and taller tires for a vehicle that is used mostly on the highway?
It's odd what you ponder when you can't sleep, isn't it?
Old 08-08-2008, 01:49 PM   #2 (permalink)
Civic - '98 Civic DX
90 day: 41.44 mpg (US)
I would think that even in town taller would be better for the change in gear ratios.
maybe someone needs to do some A-B-A testing.
Old 08-08-2008, 02:15 PM   #3 (permalink)
Icarus - '011 Mustang GT
90 day: 20.71 mpg (US)
There is no cookie-cutter answer to that. There are many factors (including frontal area - the higher ride height is worse) than just overall gear ratio. Having a LRR tire is more critical than minor variations in tire diameter, all else being equal.
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 140 11-21-2011 09:13 AM
Tire pressure (of winter tires) tasdrouille General Efficiency Discussion 20 08-12-2009 01:38 AM
Tire Size Improvements Blue07CivicEX EcoModding Central 11 07-25-2008 02:44 PM
Correcting for tire size whokilledthejams EcoModding Central 15 07-22-2008 07:16 PM
SAE Paper 800087 – The Effect of Inflation Pressure on Bias, Bias-Belted, and Radial CapriRacer Hypermiling / EcoDriver's Ed 18 07-06-2008 06:36 PM
