Old 03-30-2013, 09:22 AM   #1 (permalink)
vacationtime247's Avatar
The Toylet - '87 Toyota Supra 350 Chevy V8 / 700R4
In-Durrrr-Oh - '09 TMEC Enduro TMEC 200cc Enduro
90 day: 60.9 mpg (US)
Tem-poo - '86 Ford Tempo GL 4 Door 2.0 Liter Diesel 5 Speed
90 day: 47.52 mpg (US)
Ass Tick - '01 Pontiac Pontiac Aztek GT 5 Door
Green Baby Poop Stain - '01 Pontiac Aztek Aztek Base Model
Black Track - '01 Pontiac Aztek GT
Tire Size Change and Speedometer difference?
Came home last night from work and had to go back out again. Found one of my tires were flat. So, this morning I went and replaced 3 of the 4 tires. The 4th was a good used one so I didn't bother, plus I'm cheap. Nevertheless, found a deal on new tires for $58 each, total for 3 new mounted, balanced, installed and tire disposal fee was $185. Not bad. But upon closer inspection the new tires were of a different size. The back tire has the different sized tires. This going on my Diesel Tempo
Factory size was 185/75/R14 New tire size is 195/70/R14. What difference is there in MPH? Think I'll notice any change in MPG? Just curious so I'll know how to calculate for the difference in mileage upon fillup.
Fly out today to purchase my house in California, so if I don't respond quickly I'll go ahead and thank y'all in advance for the answer.
VT247
Old 03-30-2013, 10:52 AM   #2 (permalink)
RobertISaar's Avatar
MC SBX - '95 Chevrolet Monte Carlo LS
Last 3: 29.75 mpg (US)
Tire Size Calculator - Discount Tire Direct
that should help you out. total of a .7% difference. i would attempt to keep the odd pair on the non-driven axle, otherwise constantly differing tire speeds could play havoc on you differential. with this small of a difference, i don't think you'll see much difference though.
Old 03-30-2013, 11:20 AM   #3 (permalink)
.7% might fall within the range of manufacturing tolerances for any tires of "the same size".
BTW I was just shopping for tires too- had quite a few cords hanging out of a lumpy tire on the T-Racer (extracted the last mile outta that sucker!) found some nice Guardsman (Cooper) tires at Sears for $46 each; brought them elsewhere for M+B for $20 total. They are 185/70s vs 185/65 stock; I put them on the front for a 3% "overdrive".
Old 03-30-2013, 12:29 PM   #4 (permalink)
HypermilerAX's Avatar
AX - '95 Citröen AX
307 - '04 Peugeot 307 SW
Don't think it's a problem with such a small difference. 0.7% is the difference between a new tire and a 25% used tire of the same size. The differential is always moving, even with the same tire size.
Citroën AX 1.5 D 430.000 km
Peugeot 307 SW 2.0 HDI 136 195.000 km
Old 03-30-2013, 01:19 PM   #5 (permalink)
Thanks, didn't think there would be much difference. Time to go west.
VT247
