View Poll Results: Help with tire size
Don't worry about the 2% difference...get 185/65/15 2 66.67%
Keep the speedo the same...get 195/65/15 1 33.33%
Voters: 3. You may not vote on this poll
Old 10-03-2009, 01:02 AM   #1 (permalink)
Cycling more to drive les
White 'rolla - '05 Corolla LE
90 day: 44.39 mpg (US)
Send a message via AIM to Chalupa102
Tire size help
For a few months i've been wanting to get new wheels. I know that the ones i have now are robbing my fuel economy. The tires are 205/50/17 with a 17x7.5 rim. I always thought they were lighter, but in actuality, they are the same weight as my winter wheels .
I know that winter's fast approaching, but can't wait any longer. Found a decent set of 15x6 steel rims for relatively cheap that i could buy. Of course, i would be looking for skinnier tires. The car originally came with 195/65/15. I have 2 choices, stay with that size or get 185/65/15.
The only problem that i see with the 185/65/15's is that they would throw off the speedometer by about 2%, which means if the speedo says 60 MPH, would really be going 58.8 MPH.
What tire size would u guys go with?
Corolla aeromods thread:
http://ecomodder.com/forum/showthrea...ead-11210.html
Old 10-03-2009, 01:16 AM   #2 (permalink)
Matt Herring's Avatar
Bone's 2010 Prius - '010 Prius Black
90 day: 56.78 mpg (US)
As long as the tires are going to give you the traction you need year-round I wouldn't worry about the speedo being 2% positive...the best balance of winter grip and economy is probably the way to go. Plenty of guys on here run tires that throws their speedo off. I'd be more concerned with the effectiveness/economy of the tires vs. the math of the speedo.
Old 10-03-2009, 07:41 AM   #3 (permalink)
Tire Geek
CapriRacer's Avatar
Don't use the 185/65R15's:
1) That would be going down in load carrying capacity and that increases the risk of a load related tire failure, which sometimes has tragic results.
2) There is probably a very slight RR penalty for using small tires.
Old 10-04-2009, 02:46 AM   #4 (permalink)
aero guerrilla
Piwoslaw's Avatar
Svietlana - '05 307 SW
Diesel
90 day: 59.38 mpg (US)
Capri is right about load, but I wouldn't say you shouldn't do it. My stock tires are 195/65R15 and I got 185/65R15's for the winter. I did pay attention to the lower load capacity, but it was within limits. I hauled quite a few things on them and had no problems. When I'll need to replace my summer tires they'll also be 185/65R15's, no doubt about it.
So my advice is to first check whether the weight limits will be OK, and if so then go for some skinny low RR's
Piwoslaw's Peugeot 307sw modding thread
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 140 11-21-2011 10:13 AM
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 68 02-21-2010 09:45 PM
Tire size vs. hub width and weight limits Piwoslaw EcoModding Central 3 06-25-2009 07:50 AM
What effect from tire size and type? PonchoBuick EcoModding Central 1 11-17-2008 05:03 PM
change in tire size mully General Efficiency Discussion 8 09-28-2008 09:13 AM
