Old 09-17-2011, 09:37 PM   #1 (permalink)
papa smurf - '81 pickup 4wd dlx long bed 1/2 ton
90 day: 17.6 mpg (US)
Heep - '011 Grand cherokee Larado x 4x4
90 day: 19.92 mpg (US)
Old toy - '81 Cm400e
Da bike - '06 Shadow Vlx deluxe
90 day: 50.18 mpg (US)
tire wear
whats worse under inflated or over inflated?
i already replace a dunlop k571 after 4000-4200 miles and it was bald.
now my front tire was under inflated by 6-8lbs and is half worn( just pumped it up)
i got rear at 40psi on metzler marathon 880
i got front at 30psi on maxxis touring
2011 Jeep grandcherokee larado x v6 4x4. (wifes/weekender)
98 taco base 4x4 i4 toyota bought back due to a rust spot. gone but not forgotten.
81 toyota 4wd long bed 1/2 ton
Old 09-17-2011, 10:08 PM   #2 (permalink)
redyaris - '07 Yaris
90 day: 47.98 mpg (US)
Gray - '07 GS500 F
Motorcycle
90 day: 70.4 mpg (US)
KLR - '07 KLR650
Last 3: 62.78 mpg (US)
If I assume that over and under inflation is with respect to manufactures recommendation, and that you do not go above the maximum marked on the tire sidewall, then under inflation will increase rolling resistance and if you go low enough you will encounter handling/steering problems. If you go above manufacturers recommendations then the rolling resistance will go down and the fuel consumption will go down [more mpg] as well...
Old 09-17-2011, 10:25 PM   #3 (permalink)
As I understand it, low pressures give more resistance and build more heat because the tire will buckle more as it contacts the road.
I'd be careful over-inflating cycle tires though.
Jay
Old 09-18-2011, 01:34 AM   #4 (permalink)
mcrews's Avatar
The Q - '02 Q45 Sport
90 day: 23.08 mpg (US)
UNder inflation is worse.
I run 46psi (nitrogen) on my tires. I get 35-38000 miles uot of them.
When I first got the car 5 yrs ago I ran 32 like a good boy. I got 40,000.
For the improved mileage I'm more than happy.
(but, yhat on a car)
ECO MODS PERFORMED:
First, Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Second, Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
third, rear skirts and 30.4mpg on trip! http://ecomodder.com/forum/showthrea...tml#post247938
Old 09-18-2011, 06:44 AM   #5 (permalink)
Tire Geek
CapriRacer's Avatar
It's interesting that you titled this thread "Tire Wear", then ask about inflation pressure with out refering to wear in your question.
I think you'll find that there is an optimum value for inflation pressure that maximizes tire wear, but there are other consideratiuons such as ride quality, traction, handling, impact resistance, etc. that will have different values - and that may change what you think might be best.
Old 09-18-2011, 10:04 AM   #6 (permalink)
alvaro84's Avatar
Teresa - '04 F650CS
Motorcycle
90 day: 81.08 mpg (US)
Well, a rear tire often wears much faster than a front. It's the case with my Heidenau K73 pair, of which I had to replace the rear after 10250km (6370mi) (almost reached the wear mark at the 80k maintenance) while the front looks pretty new, the 2nd rear may wear earlier than this front.
With the Metzeler Z6s it was different, they got worn at the same pace, they were replaced together at 28000km (17400mi).
As a rule of thumb, rear wears faster on a stronger bike, and it also wears faster with more weight on it. My Teresa (650cc 50hp single, used mostly <4000rpm) is not too hungry compared to many other bikes today, yet half of that 10250km was 2-up which may count.
I always inflate the tires more than BMW recommends, sidewall max at most (2.9bars with the Z6s and 2.5/2.7 with these K73s).
Old 09-18-2011, 10:50 PM   #7 (permalink)
I was told I was running to much air. 40psi. When it recommends 35-36 psi (rear) that is y my dunlops wore so fast. I still say it was a soft tire.
About 10% of my riding maybe less is 2 up.
