Old 09-30-2009, 04:24 PM   #11 (permalink)
rigid tires
Some things that crept into my mind: 1- the rigid tire would have little or no traction in a locked scenario,the tread-blocks unable to deform and maintain a contact patch. 2- since there is no "air-spring" present,the rigid tire would require internal reinforcement to allow it to maintain it's form during transient loading,which would add mass to perhaps an already massive tire,upping the polar moment of inertia which would work against your mpg. 3- I find it difficult to imagine a suspension system which could isolate the multitude of vibratory impulses easily absorbed in a pneumatic tire.Should even a fraction of these impulses be communicated into the cabin of the rigid-tire car,the stress to the occupants from "harshness" might drive 'em up a wall. 4- a collision with road debris could cause a rigid tire to leave the road surface momentarily,especially dangerous if in the middle of a high speed curve,at night,in the rain. 5- should a rigid tire undergo a "failure",what kind of "backup" safety attribute would there be? You're already "riding on the rim".
DIY: plastic rear wheel skirts (Geo Metro) MetroMPG DIY / How-to 34 01-06-2012 11:40 PM
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 140 11-21-2011 09:13 AM
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 68 02-21-2010 08:45 PM
Rear wheel skirt / cover question pasadena_commut Aerodynamics 5 02-16-2009 04:50 AM
How much does tire and wheel weight effect MPG? twolostminds EcoModding Central 27 11-28-2008 11:17 PM
