Old 04-21-2011, 12:29 PM   #41 (permalink)
If I have two bicycles with the same tread but one with wide tires and the other with narrow tires, would doing a coast down comparison be a fair test of the theory?
Old 04-23-2011, 02:27 PM   #42 (permalink)
width
My opinion is that it would take a wind tunnel with extremely accurate load cells to be able to pull out the difference.Your own body is the largest drag contributor and its interference drag would play into at least the drag of the rear tire.
Technically however,the narrow tire would tunnel out with the lower CdA.
Old 04-23-2011, 04:35 PM   #43 (permalink)
There are several MB models where they specify different CD numbers for the base skinny tire version vs the optioned up big engine big tire version.
C220 coupe 0.24
C350 coupe 0.27
Old 04-23-2011, 04:48 PM   #44 (permalink)
skinny/wide
C220 coupe 0.24
C350 coupe 0.27
Yeah,my CRX was that way.Porsche 911s ditto.Trans Am Firebird.
One caveat.The wider tire may get it flush with the flanks of the car,reducing some turbulence,buying back some gain over the increase in frontal area.
Old 04-28-2011, 11:22 PM   #45 (permalink)
live, breath, Isuzu-Ds
trooper Tdiesel's Avatar
the brown goat - '03 impala base model
puddle jumper - '-1807 sidekick base model
energizer bunny - '86 trooper base model
Clifford the big red dog - '84 S-10 durango
cameo mobile - '91 trooper base or S model
road master - '86 pup base model
MPG+ pup - '81 pup DLX
comparing 33"X12.50X15 to 33"X9.50X15 tires on a older SUV with about 100hp.
the tires had the same tred lay out, and where very aggressive about 20/32" of tread.
there was on average a 3 mpg difference
0.01C
1 86 T\D trooper with rare GEN 3 rods TRANS FIXED NOW DD
1 86 4WD 5sp pup is 2.3L gas, but plan on 2.2L diesel repower
1 91 trop, long term plan is a group buy of imported Isuzu 4JB1-T 2.8L I-4 engines, hoping to get price down to 2K not 3K plus
1993 sidekick my MPG toy, epa rating 26.
i get 29/31 with stock drive train.
CdA list Daox Aerodynamics 106 03-30-2012 06:02 PM
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 140 11-21-2011 09:13 AM
aero mods-data-% change or Cd change ( installment # 7-Wheels/Tires/Wheelcovers/etc. aerohead Aerodynamics 4 08-31-2011 07:45 AM
Sources of Aerodynamic Drag in Automobiles and Possible Solutions SVOboy Aerodynamics 12 02-17-2010 02:09 PM
Tire Engineer here - concerned about hyperinflating tires CapriRacer Introductions 48 09-26-2009 09:25 PM
