Old 03-24-2012, 04:15 PM   #31 (permalink)
Best way to feed cooling air to the brakes, or for that new BMW side curtain vent, is ducting from the stagnation point at the nose, center.
The 2012 Prius deflector shown above is very crude. Coulda had a combined wheel fairing/duct that would have been much more efficient means of fairing the wheels, while simultaneously cooling the brakes.
Old 03-24-2012, 04:26 PM   #32 (permalink)
The Truck - '02 Nissan GU Patrol ST
So then I assume the Subaru, being much the same is also crude and I should have no fears in attempting an improvement.
What do you think of the serated version on the Merc in this link?
News - Automotive Engineer
Old 03-26-2012, 12:31 AM   #33 (permalink)
It would be easy to do a knockoff of the depicted Mercedes deflector, out of, say, a section of plastic paint pail with crenelated edge.
I wish they'd included all the streamlines in their drawing, especially showing the air at and immediately around the tire and front corner of the car. Some streamlines appear to originate at the tire leading edge, so they should show where that air came from. Is this a variant of the recent BMW air curtain idea, or what?
And, their computerized streamlines vary considerably from actual smoke streamlines as shown in Hucho's wind tunnel work on the Opel Calibra, which is much more acute oblique flow at the nose.
Best way to check, seems to me, is do your undertray, then tape tufts of yarn off it, wet the tufts with tempura paint, drive down the road at 70 mph, then look under the car and see which way the wind was blowing, from the paint deposits on the undertray. Then, orient your wheel fairings accordingly. Based on Hucho's photos, I suspect your streamlines will look more like Hucho's photo than the Mercedes drawings. In any event, the yarn tell tails will tell the tale.
Old 03-26-2012, 02:54 AM   #34 (permalink)
PSmodder lurker
Crenelated edges or tubercles, the finer details of these wind/fluid deflectors. With props from bio-mimicry.
http://www.otherpower.com/images/sci..._tubercles.pdf
Shaman Kayaks by Ventura Artist John Petersen
I always loved their taglines,"...million years of field tests" Whale-Inspired Wind Turbines - Technology Review
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 144 01-25-2016 11:39 PM
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 69 12-27-2014 01:17 PM
Bounce Test for Rolling Resistance? Ernie Rogers General Efficiency Discussion 14 05-25-2009 06:38 PM
