Go Back   EcoModder Forum > EcoModding > The Unicorn Corral
Old 07-06-2011, 07:46 PM   #1 (permalink)
marcusmodder
orange4boy's Avatar
The Golden Egg - '93 Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Prius
90 day: 57 mpg (US)
"TireBlast TM" Canadian tire verging on unicornian claims
Nitrogen tire inflation
Improves fuel economy
Increases tire life
Less loss of tire pressure helps prevent uneven tire wear
Reduces wheel corrosion
Tires run cooler adding tire life
Then they sum it all up in a sentence just for "clarity"
"Nitrogen tire filling will increase safety and reduce operating costs, while improving the performance of the vehicle."
$6.95 per tire.
All that for just 6.95? Such a bargain!!1! So how to they get all the old horrible wasteful regular 78% nitrogen air out completely? They must pull a 100% vacuum before right? right?
The biggest reason they left out: Avoid those terrible tire fires you have heard so much about.
Anyone wish to do the cost/benefit analysis and return period?
Old 07-06-2011, 09:25 PM   #2 (permalink)
The road not so traveled
TheEnemy's Avatar
The Truck - '99 Frontier xe
90 day: 25.74 mpg (US)
The Ugly Duck - '84 CJ7
For the same price, and can fill several tires.
Amazon.com: Q Industries HV35 SuperFlow 12-Volt 140 PSI Air Compressor: Automotive
And works anywhere you have your car.
Old 07-06-2011, 09:33 PM   #3 (permalink)
I are aerodynamic kitteh!
t vago's Avatar
2000 Fiat Dakota Quad Cab - '00 Dakota Quad Cab SLT
90 day: 18.33 mpg (US)
Dakota A-B-A HAI - '00 Dakota Quad Cab SLT
90 day: 19.38 mpg (US)
But... but... but...
You'd be filling those tires with contaminated nitrogen! Ewwwww!
2000 Dodge Dakota Quad Cab
2002 Chrysler Sebring Convertible GTC with transplanted 3.5L LH engine
Old 07-06-2011, 11:20 PM   #4 (permalink)
Ryland's Avatar
honda cb125 - '74 CB 125 S1
90 day: 79.71 mpg (US)
green wedge - '81 Commuti-Car
Blue VX - '93 Civic VX
It's dry nitrogen tho, after all on average the air going in to your engine as as much water in it as gasoline as it enters the combustion chamber, so while I question if it's worth the cost, it does have an affect, airplanes use nitrogen in their tires to keep them stable, of course your car is not seeing the changes an airplane sees.
Old 07-07-2011, 12:14 AM   #5 (permalink)
mcrews's Avatar
The Q - '02 Q45 Sport
90 day: 23.08 mpg (US)
On my last set of tires, I had Radial Tire Store of Sacramento, put nitro in the tires. we had discussed it half way thru my last set and he said that it really needs to be done when the new tire is installed.
I run 44psi w nitro and the psi fluctuates 1psi (the Q45 has psi senors. In the past it was as much as 4psi different hot and cold.
The trip that is documented in my signature (third link) was my first ever over 30mpg.
I reallt thing the nitro played a role in that.
ECO MODS PERFORMED:
First, Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Second, Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
third, rear skirts and 30.4mpg on trip! http://ecomodder.com/forum/showthrea...tml#post247938
Old 07-07-2011, 02:08 AM   #6 (permalink)
marcusmodder
orange4boy's Avatar
Chewie - '03 Prius
90 day: 57 mpg (US)
Really, though, the slightly increased stability of psi may really be the only material advantage. So if your peak psi is a bit higher without the nitrogen it's not going to be doing you $27.80 plus tax better any time soon.
Gotta love the ill chosen name: TireBlast. Heh heh.
"Neglect your tire pressure even more with TireBast!"
Old 07-07-2011, 02:34 AM   #7 (permalink)
5 Gears of Fury
War_Wagon's Avatar
Lumpy - '00 Insight
90 day: 49.98 mpg (US)
Grendel - '00 Firefly
90 day: 39.17 mpg (US)
Salty - '91 Tercel DX
90 day: 35.27 mpg (US)
Though you are all missing the major benefit of the nitrogen filling - the green valve stem caps you get!
"Don't look for one place to lose 100 pounds, look for 1600 places to lose an ounce." - Tony DeFeo
Old 07-07-2011, 06:46 AM   #8 (permalink)
Tire Geek
CapriRacer's Avatar
Barry's Tire Tech
Old 07-07-2011, 09:50 AM   #9 (permalink)
t vago's Avatar
Old 07-07-2011, 10:35 AM   #10 (permalink)
Empty Pocketed Ecomodder
Gen - '05 Liberty Sport
90 day: 22.09 mpg (US)
Blurry - '03 Focus SE
90 day: 35.31 mpg (US)
^^^ they probably make a killing off of that stuff. I can do the same thing by using an air compressor and paying attention to the pressure by checking it weekly.
